All Forum Posts
Badge glue?
The enamel badge on the timing case of my dominator 99 has disappeared along the road somewhere, I have a new one from RGM Norton, but I'm looking for suggestions as to what to use to stick it on with to stop the same thing happening again?
indicators
Hi, with having no indicators on my bike when i come to turn a corner its getting harder to hold my arm out. my thoughts were of sewing some of these into my jacket one on each shoulder and wire them in.
Dominator 99
Hi All,
I am about to undertake rebuilding a 99 crankshaft, and the next step is to centralise the crankshaft. However the inner race is stuck fast, probably corrosion. My questions are -
1957 Dommi 88
I am back in the sixties my friends !!! after going through probably fifty different bikes since then I have the exact model I had then. Same colour which is my question.
I am a newbie and this info may be on this site somewhere .
Dominator 99
This is an addendum to my previous question to include a camshaft photo, because every time I tried to attach it to the previous question all my text disappears.
-Andy
Re: 1947 M18 Petrol tap
Hi. The o/s push on-pull off fuel tap on my 1947 M18 has decided to start leaking. I've tried a new cork washer but the female thread immediately below the push-pull has almost gone so i can't tighten anything back on.
LAYDOWN GEARBOX BUSHES
I'm having great trouble getting out of gear when stationary. I also have a lot of play (wobble) on the gearchange shaft - presumably worn bushes in inner/outer casing.
Would the latter contribute to the former?
TLS brake
The lad is complaining about the front brake on the Atlas, all looks OK but notice its possible to assemble the brake with the cams in 2 different ways, cams pointing towards the axle or outwards as the cam is offset to the spindle.
rear wheel cover rivets
hello as anyone had ago with these rear wheel cover rivets there very hard to drill and will break drill bits, even under a press drill with a cobalt broach drill fitted or is there another way I am all ears, yours Anna J
navigator head gasket
hi have just bought (5 days ago)a navigator,i want to buy a head gasket but there are 2 types spiggotted and non spiggotted advertised ,any advice on which i need,also i when i bought the bike i knew it was sedate,is there anything i can do to imp
ES2 big end
I have purchased a new big end for my ES2 500 cc single norton engine number. 41050 4. 79 X 100 but it is too small for connecting rod E4099. It has a 1" 3/64 size pin and requires one with a pin 1" 17/64 . Can any one help?
bar raisers
The traditional Atlas bars look fine but drag the cables over the fork nuts. Has anyone fitted bar raisers ?and were the fixing centers ok?.What are the threads? longer fixings needed.Plenty on E-bay for modern bikes.
NOC Solent.
What a great choice of venue for our turn up meet nice roads and a fine pint at The Royal Oak Midhurst well done chaps.
