Hi could anybody enlighten me to the function of the 'compression plug' screwed into the head of my 1950 Big 4. I'd also be grateful if anybody could suggest a supplier for the compression plug sealing washer as my poor old beast has spent a large part of its life with a spring washer in its place slowly weeping all kinds of muck into the fin valleys.
Chris
Previously chris_howard wr…
Thanks for that Alan it wo…
Thanks for that Alan it would definitely be convenient for finding TDC. Trouble I'll have, when I get it back from having the face skimmed is getting it out without damage, but that's part of the fun of having and old bike.
Thanks again
Chris
On the iron head models, t…
On the iron head models, the centre plug had an 18mm thread in common with the sparking plug. Did they alter that for the the alloy heads ?
The easiest option is a sparking plug crush washer either 18mm or 14mm, as applicable...If you're worried about clearance, two probably wouldn't hurt.
Previously chris_howard wrote:
Hi Chris, I always believed it was for checking for top dead centre, be very careful when fitting a suitable sealing washer! I replaced mine with a thin copper washer and the tip of the plug started touching the piston when the engine was running. That night explain why you had a spring washer, put there to gain the required clearance.
I sorted it by shortening the plug very slightly.
Regards, Alan
