All Forum Posts
engine sprockets
hello,
i am having trouble fitting the correct engine sprocket on my dynamo 88 engine. it jams halfway
i have a larger 22 tooth sprocket and it fits snugly and there is about a 1mm between the 2 inside bore.
Rigid Frame
Hello,
I have a rigid frame that has been converted to a plunger.
I would like to have the rigid rear end back.
MC275 rear rim
Having recently acquired a good hub to replace my damaged one, I eyed up the job on the existing wheel and noticed the spokes look stressed.
Navigator oil Pump
Hallo all,
I converted my 1961 Navigator oil pump form a 3 start to a 6 start pinion gear.
Can the Navigator oil sytem cope with the higher oil flow?
I noticed oil seeping out from under the cylinder heads in the last time.
