Swap plugs to start
An old friend of mine who has owned vintage cars and bikes has one 1920 'sracing car that has a rack for plugs to be used only to start up and warm up.With modern plugs I've never considered it. But today after maybe a month sitting still and (and just a pint or so wet sumping) my 16 H started easily on its magneto.The Dommie totally refused. To be fair it has no battery at present. Electronic RITA ignition is usually OK since it has a Boyer Power Box. But it strikes me that hotter plugs might help. Does anyone bother to use special plugs when starting? I put a battery on after a few false starts but still no joy.Naturally I could not find any clean spare plugs...time to raid the piggy bank...David
Find some really old ,old plugs give them a clean and try them,modern plugs are not designed for oily old clunkers!.
Really? Why then did you advise, a few hours ago, on another thread, that it is not worth cleaning an old plug?
Its not worth cleaning an old MODERN plug as its insulator is porous, an old OLD plug is something different as it has a glazed insulator which is non porous and will clean. Find some really old plugs and put them in a safe place ,you may need them someday.
After years of difficult starting using NGK plugs I read a piece on the Green Plug company's web site that stated that the modern insulaters are porous and don't like to be flooded with petrol.
I sent off for some pink Lodge plugs ( apparently race plugs) and the bikes now start remarkably easily.
Back in the sixties, we always had warmup plugs for our methanol burning J.A.P, ESO and Jawa engines. If I remember correctly, it was something like Bosch 225 and then 460 for racing.
All makes sense. Everything we buy today makes one step forwards and one backwards. My plugs are filthy and black all over the insulators. I tried grilling one on the gas cooker but that didn't help! As Robert says..they seem to be porous.
If your plugs are black all over the insulators they will be tracking - hence not starting. Sounds like you are running too rich. Nothing an electrical current like better than a low resistance carbon path to follow rather than jumping across an air gap. You really shouldn't need different plugs to start and warm up unless you are running exotic fuels.
Thanks, Gordon. I hope this is mostly oil and petrol from trying to start the thing. But I can't begin to get them clean. They haven't been sinister in the past although I admit I have not adjusted the pilot air screws for some years and a good few thousand miles.It's not as easy as it used to be to buy plugs now that the old days of motor factors on every high street are sadly long gone. I have not made it easier for myself by running without a battery since a cell died on my last one. It's never as easy to start on the Boyer box - I suppose the first few kicks just charge the condenser, and if it does spark then the next couple of kicks re-charge it I imagine. And meanwhile the plugs foul up or it floods...I must fix the magneto!
