Valve washers
Hi , do we use these heatproof washers that go under the valve cups on a dominater ?
I have been rebuilding my brake calipers with new pistons and seals, but whatever I try I cannot get the piston in without damaging the seal. Have tried soaking them in brake fluid, rubber grease, stretching etc.
I am a new member and wanted to ask if anyone has replaced the exhaust rose with stainless steel versions?
I ordered a new side stand for my '55 ES2 from Norvil. I rang them to confirm that it would fit as it was advertised as "stand - side - ES2, 7, 77, pre-featherbed". Mine is a pre-featherbed.
Has anyone used this company before Any personal views would be appreciated
Had my bike ready for renovation for 18 years with no time to even start it but now i have time. Going over whats missing in my boxes and no clutch parts, the last owner did say he was looking at belt drive so he must have removed it.
hi , not sure if this is the right place to ask questions on the p11 ?
Would anyone have pictures or knowledge of a 350cc Manx Norton being raced in the 60/70/80's that had a fairing fitted in early 60's and most noticeably had a Lockheed front disc brake fitted during the 70 - 80's.
It's a long embarrassing story which involves me spending a lot of time fixing and preping a tank which I finally discovered to not be from a Navigator.
Curses
Seen a seat cover on eBay (classics) Norton7 dominator black/red piping WideLine 500cc 1952 seat cover £32.95.
Are the covers any good as my base and foam are in good order but seat cover a bit tired.
I don't know what its called but it is the lower part of the instruments on 1955 88 dominator never seen one for sale, has anybody got a photo so i could maybe make a copy, or know anyone who can supply the part.
Hello has anyone fitted any of these con rods. it says they have to be balanced would that be the case or could i just fit some without the balancing.
Hi all,
Just putting a clutch together from a tub of clutch bits. Works out I have enough bits (Inc new rubbers) to make up a pre 57 clutch. I can't remember how many drive plates I put in my other model 50, 18 years ago.
I have just acquired a 1961 ES2 and am having difficulty finding technical literature. I found and printed a PDF labeled "maintenance manual". It's a start, but I was hoping for something more in-depth.
What do other ES2 people use?
Hello All,
I am slowly making progress with the Navigator. MY rolling chassis is about there--non standard as before BSA front end. I do intend to fit a side stand.
I have lots of good parts that need platting mostly spindle brackets etc small stuff but costly or impossible to replace. Just wondering the cost of this work average prices.
Am I allowed to name names? If not, I apologise and leave it to the judgement of our excellent elves.
I have 2 v good hepolite pistons with ring i am not sure about no marking etc. what rings can i fit to the pistons +20 thou stamped on the head.
Hello,
Anyone any idea if iron head are the same as alloy head pistons?
I have alloy head 54, trying to find some, andover have iron head listed.
Only difference I can see is 0.1 comp ratio
Thanks Marcus.
Is it possible to change the rear iso. washers without dismantling 1/2 the bike?
I striped the my 500 88 back in 2002 and its lived in cardboard boxes ever since, it has plus 20 thou over pistons hepolites in great shape but can't work out the rings packed with the pistons.
Just come onboard the owners club but been looking for some time.
I am having great difficultly starting my 650ss when hot.
Thorspak ignition is fitted & new Monoblocks
It willeasily start with a bump & runs perfectly, the plugs are a
I have a late 71 750 Roadster, after having all sorts of issues with the wiring i decided to enlist the help of a professional vehicle electrician.
I have a MCR2 voltage regulator fitted to my 1935 ES2, is this correct for the year? If not what should be fitted.Thanks.
Just been offered a 1928 model 18.What is the engine spares situation like for one of these?Thanks.
This Government was supposed to be in favour of Law and Order. The Police force is seriously underfunded hence 850 Commando theft not investigated. The NHS also. So long waits in A & E. That is if your local one is open.
We have two systems of posting on here neither has an adequate spell checker!
Hello, Has anyone else had problems fitting one of LUCAS wiring looms.
