What Regulator for '35 ES2?
I have a MCR2 voltage regulator fitted to my 1935 ES2, is this correct for the year? If not what should be fitted.Thanks.
Hello Nicholas,
The MRC2 is post war.The earlier, less tall, MRC1 was introduced in 1937.Up until 1936Nortons didn't have regulators as such, a three brush dynamo, a reduced charge resistance coil on the switch/ammeter panel and a four position light switch to select charging when required was all the order of the day. I kept the original setup for some time but got fed up with the occasional blown bulb so a two brush dynamo conversion and the fitting of a modern electronic regulator hidden under the saddle keeps the pre-1936 appearance without any of the hassle.
Below a pre-regulator wiring diagram and a photo of my own V-Reg II Dynamo Voltage regulator fitted beneath my sadle.
Hope this helps.
Previously Pete McDermott wrote:
Hello Nicholas,
The MRC2 is post war.The earlier, less tall, MRC1 was introduced in 1937.Up until 1936Nortons didn't have regulators as such, a three brush dynamo, a reduced charge resistance coill on the switch/ammeter panel and a four position light switch to select charging when required was all the order of the day. I kept the original setup for some time but got fed up with the occasional blown bulb so a two brush dynamo conversion and the fitting of a modern electronic regulator hidden under the saddle keeps the pre-1936 appearance without any of the hassle.
Below a pre-regulator wiring diagram and a photo of my own V-Reg II Dynoamo Voltage regulator fitted beneath my sadle.
Hope this helps.
Thank you very much Pete.I didn't realise that they didn't have a regulator in that period.So much to learn, so little time to do it in.Thanks again.Nick.
