All Forum Posts
1935 Es2 speedo type?
The speedo I have fitted looks like a Smiths type, it goes up to just over 80mph. It has no trip meter on it and only has Made in England running along the top of the dial and Chronometric in the middle.
Undies.
Rag: The most unsung tool of all.
I always know when I'm going to get some rags for the shed. My dear wife decides she's had enough and gone out and bought me some new undies.
Hepolite pistons
How do you tell a genuine nos hepolite piston from a new hepolite been sent some sold as nos but not convinced they are all they have is 6.92 on the inside but with ae rings
Mk3 Gearbox
Trying to put my Mk3 gearbox together. I cannot fully engage 4th gear in that the camplate falls just short of the plunger, all other gears are fine I have stripped it numerous times but can't see what the problem is, any ideas?
1946 Model 18 oils
Looking for advice on what oils to use in the engine,gearbox and primary on my newly purchased 1946 model 18.Straight 50 (with or without detergent)? This is my first Norton.....
Stephen
Stiff clutch
The kiddies, (mere 40 year olds) have been wimpishly complaining about the clutch on the 99 so I have replaced 50 year old cables and springs with super nylon lined and graphite lubed cables,found new easy run route etc,etc.
ES2 Headlamp
Silly question no.1; are the small brackets on the sealed beam unit for holding the "W"clips? Silly question no.2; which side of the sealed beam unit do the spring prongs on chrome rim go - in front or behind? George
