Securing Atlas spigot recess rings
Are they just put in place and the bolting up and torquing of the cylinder head secures them or is there other steps to be done?
Ive just fitted a new Primary case seal to my 1949 ES2, cut to size as instructed and not overtightened the outer case either, Still leaks !!! Is this a common feature to these singles that I will just have to live with ?
Hi, After the excellent reply to my query on the gearbox capacity of the Navigator could I now ask what the primary drive capacity is please.
I bought one, might not be correct, I can't figure out how/where in goes, and can't find a photo. IA pic would be so helpful.
1961 99
Steve
Newly on the road my 12v Boyer ignition Navigator with a new regulator seems to run fine, but the ammeter indicates a good +ve charge of up to 8amps (6V ammeter though) then will swing to -4 or there about at a highish rev, occas
Hi, could anyone please tell me the gearbox oil capacity for a Navigator please.
I may have to make some solid pushrods for a friend's British twin AJS ( yes not a Norton but he has a Triton so he has half a Norton).
what oil grade and type is the best and most common used in 850 electric start commandos
Hi, quick question, what is the best way to remove an errant bullet (separated from its cable) from a double connector - it's not the end of the world I can always replace the connector, just intrigued!
Big grin today...back on this beast after 7 years. Woke up the neighbours on a quiet Sunday afternoon. Thanks to all who provided helpful comments.
Following apparent delamination of the tread on a TT100, I suddenly needed a pair of new tyres, as the other was due for replacement anyway. With a pair of Avon's almost £100 cheaper than two TT100 I took this as God's way of telling me it was ti
Would anyone know the fixing position of the Jubilee mudguard stay. Such as the distance between the stay and bottom of the forks. Recently resprayed forks, trying not to mark the paint.
John.
Edgar Franks quotes 52deg BTDC for the prewar Inters. But the post war value is 42.5 deg. There was, of course, only Pool petrol for rather a long time after the War. Does anyone know if that's why?
Edgar Frank's quotes 52deg btec for the prewar Inters. But the post war value is 42.5 deg. There was, of course, only Pool petrol for rather a long time after the War. Does anyone know if that's why?
Just about to fit a new Primary chain case seal (rubber band) to my 1949 ES2 to see if it will cure the leak at all, I pre fitted the new seal (bought through the NOC shop and it doesn't fit snug around the case, its pretty loose.
My bike has a belt drive fitted. This means that the alternator has to be spaced further out than with chain drive (bike purchased already modified) and this poses a problem with fitting a timing disc to the end of the crankshaft.
Hello, I'm new here. I have just bought what I believe to be a 1970 Slimline Featherbed frame.
The only identifying mark I can find is on the gusset below the headstock (99546). Has anyone
Does anyone have any experience of using the modern spray-on chain wax on primary chains?
I'm trying to avoid the drip-drip situation with the old pressed steel primary covers.
The bike will not be doing high mileages.
As the barrels on 600 / 650 modes were interchangeable, does anyone know how the extra stroke was accommodated without a taller barrel?
Steve.
A 1930's Inter has arrivedin the shed somewhat to my surprise! I'm trying to do the right thing before I start it up to avoid damaging the engine. It has Castrol R40, and hasn't run since 2012.
Hi.
I have got a wideline featherbed frame that i need some info about. This frame is in chrome. Does anyone know anything about this? Is this a frame that is made like this new?
My 1935Es2 magneto chain is so loose its surprising it stays on the sprockets. So I need to replace it, I assume.
Having just topped up my 19S at the local Esso station in North Warnborough, Hants., I noted the placard below relating to Esso <
This subject has become very quiet. What exactly is happening. As a members I am sure we would be interested to know.
I haven't really understood the evolution of Norton clutches. There seems to be a number of different types in postwar years. Different number of plates, different plates, sometimes steel plates with tags out and sometimes in, even width of tags.
Can anyone assist please: is this a standard Amal TT carburettor? The inlet tube is missing. I'll be in touch with Surrey Carbs later, but the Amal publication says that the air tube must be factory fitted.
Bike is 1959 Model 50.
I have replaced the kick start oil seal twice now. The seal works for a few months and then it begins weeping again. Any ideas on how i can reolve this in a more permanent way ?
Having lately received my August edition of Roadholder I noticed that our esteemed organisation has produced a Diamond Jubilee badge to adorn our pride and joy machines.
