All Forum Posts
Oil Pump
The oil delivery into the oil tank at a fast tickover on my 1956 Dominator 99 is a continuous full stream.
Anti dran valve
I've had an anti drain valve on my Commando for ages with no problems at all and thinking about fitting one to my 19S (1956).  As the bike is used infrequently it's a nuisance to drain the crankcase before every ride, and I like the "fit and forge
Carb set up
I am having issues with my 1972 Commando. It won't rev past 4,000 rpm. Can someone tell me what the correct carb set up is for the Combat engine, jet sizes, needle position etc. Thank  you
Torque settings.
Does anyone use a torque wrench to tighten the engine sprocket and clutch basket? If so what should i tighten it to on my '35 Es2?  Be nice to have some idea instead of just guessing as I usually do. Many thanks .
oil leakage
I have in the main a couple of annoying oil leaks on my 1956 Dominator 99 which in particular I seek advice. ( do have others too of course ).
International rally Holland
Thans to the Norton Club Holland for a beautiful rally. Many interesting events, and unusual bikes.  On this subject, I would be interested in learning more about the Klapton! Could we hope for an article in the Roadholder, for instance?
correct ignition coils
I am soon to start on the electrics on my 1964 Navigator it will be 12 volts and with have Boyer Branson EI, I see that there's a number of options for the ignition coils ranging from the Boyer micro ones to originals coils, the question is which
Commando Pistons
Browsing the Norvil catalogue and noticed that Hepolite pistons are priced at 83 pounds and another anonymous brand at 155 pounds, nearly double.Can someone please explain- what is so special about the latter pistons.
Regards- Bill
clutch es2 laydown box
great ride out last week, starting and charging well [thanks to Tony Cooper and A.O.]
But he ride was spoilt by the clutch....worked fine to start with then gradually got more difficult to change gear, finding neutral was horrendous.
