ES2 Oil Tank
I have a 1955 ES2 and the oil tank has a feed pipe connection at the rear of the tank, in addition to the usual outlet and return pipe connections at the front of the tank.  Is this normal and if so where does it feed to?  Unable to find any information in the books/photos I have.
Can you look inside the oil tank and see where "feed pipe" terminates in the tank?
I am thinking that it is just the vent pipe.  There should be a hose that directs the vent to the ground or to the top of the chain guard.
Thanks Mike, I have had a look and it is on a pipe to the top of the tank so it is a vent as you suggest.
Martin
... that it was designed so that you can attach a small pipe and use it as a rear chain oiler. That's what I've done with mine.
This is correct.  My 1955 ES2 has a small bore copper pipe that points at the rear chain.  It's not easy to take a photo as it's quite congested behind the battery carrier.
There's not much evidence that oil or mist gets to the chain though!
Philip
