16h spark plug cap
hi what is the best spark plug cap in the limited space under the tank
If it's a WD16H, then there is very little room. The frame tubes are 1" shorter and you have the flat-bottomed fuel tank with just a tiny dome above the plug.
Unlike the BSA M20 which came with the nice screw top KLG caps, the WD16H was always supplied and used simply with the brass tag on the HT lead, retained by the KLG spring clip...
With a smaller modern one-piece plug, you could probably get a rubber Lodge type cap in there, but with a mica KS5, there is no room at all. I have a rubber sleeve over the brass sleeve.
KLG KS5
No plug cap on mine. Ignition lead has a crimped ring held on by the screw collar on top of the plug. Some plugs have a dummy collar...
