All Forum Posts
head stock stamping
Does anyone know anything about a 'Stafford Henry', this name is stamped on the headstock of a featherbed frame that my friend  is working on?He tells me that he can see that the various additional bracketry that has been added is to a very high s
750 crank turn
Hi , I’ve removed the head on my 750 , while it’s off I imagined I should be able to turn the crank with a socket on the engine sprocket shaft and check bores , when I turn it locks at top of stroke ?
Jubilee insurance
After many years, hoping to finally have the Jubilee on the road early summer. Can anyone advise on a good reasonably priced insurance company. How much are you guys paying for your Jubilee insurance his year.
John.
Mk3 starter sprag failures
Pulling my hair out with starter sprag failure every time i go out, renewed engine sprocket, starter drive gear, bearing collar and both washer's, one of the 18 pegs cocks up and it fails, tried new sprags, anyone had a continuing problem ?   than
E010 Fuel
Bit of a turnaround..  The government is now telling us that E010 fuel will damage our classics with time.   But does that not mean that E05  would just take longer to do the damage. Anyone still unsure or living in cloud  cuckoo land.?.
Atlas forks?
Hi as a newbie I was enquiring if someone with more knowledgeable could help me identify the forks om my 1966 Atlas as the appear to be the commando type, the yokes are silver in colour and the nut is on the bottom yoke and the pin is attached to
