All Forum Posts
Spark plugs
Hi all, 750, hi comp head. Currently has Champion N7YC. What's the spark plug of your choice? Laid up in hospital so look out for more questions!
Thanks.
Oil pump drive
My understanding is that the lightweights had a 3 start worm to drive the oil pump, later on a 6 start worm was used.  Is that correct?  Presumably done to increase the oil flow through the engine.
Frame straightening
I have just acquired a 1969 750 that I think has had a front end bash at some point in its past life. It came with a disc front end in the pile of bits. Presumably, the drum front end was scrap, but the frame needs attention.
AGM Voting
Hi All,
As secretary of Thames Valley branch I sent out the email below to all in my branch, it was suggested that it may be worth wider publicity, so here goes:-
Mudguard stay mystery
I have two front mudguard stays (see attached pictures); the grey painted one is from my current 1972 Fastback, while the rusty chrome one was removed, 40+ years ago, from the 1971 Fastback that I owned back then.
Wideline tank rubbers
I would like to ask how the tank spacers was attached  by the factory: https://www.rgmnorton.co.uk/buy/featherbed-petrol-tank-frame-u-section-rubber_3062.htm
Mine are attached by adhesive tape and it doesn´t look satisfactory.
Peter Cocks
I heard recently that Peter had passed away, surprised there is no official announcement on the website? Peter was a great Chairman and ambassador for the club. He was at our inaugural meeting of the Tay Valley Branch.
Headrace Removal
Hi all. Both headraces in the frame of my es2 plunger have no grease holes so I want to replace them. I’ve tried drifting them as hard as I dare and they aren’t budging. I don’t want to use heat and ruin the paint.
Which engine.
I've recently bought a 1973 Commando 750 John Player Norton replica. Engine/frame no. 210678. This was originally an ex Police  Interpol. Anyone know if this is  Combat engine? Has the tower breather rear lh crankcase.
Oil viscocity
I have a question about the oil in my Norton model 7. Just purchased from Belgium and shipped to the N.W. USA. I have come up zero trying to find a manual so I can get the bike ready to ride ! What is the correct level in the tank ?
Carb slides stuck
Rebuilding my 1972 Commando combat. Removed the carbs for strip down and clean etc. The slides in both carbs were seized and took a fair amount of effort to get out of the body. what is the best (and safest) way to free up the movement?
