All Forum Posts
Fork yokes
Can anybody identify yokes numbered 15675? Judging by the trail I suspect that they might be for sidecar use but I know little about forks other than for featherbeds and later.
Alan
20 inch tyres
I'm nearly at the stage where I am ready to get some wheels built up for my Inter project and it should be a 20 inch on the back. But I dont seem to be able to find much in the way of 20 inch tyres.
Precision re-bores
At last, after re-bores by the local Norton 'specialist' and one or two others, I've found a company who can properly re-bore a cylinder toan out of roundness tolerance of within 0.0002'', 360 degrees and top to bottom of the bore.
Cleaning Amal carbs
Prior to reconditioning my Concentrics I soaked all parts in petrol hoping to release calcium? deposits but alas it did no good, could someone suggest a more satisfactory way to proceed?
Many thanks
Jim
Members discount
The NOC membership does not seem to entitle members to much in the way of discount from any of the main spares suppliers. In fact none.
Clutch cable adjuster
Having rebuilt AMC-type gearbox number N11127 I'm now having trouble working out which clutch cable I should have. The bike is a '59 Featherbed with no adjustment at the handlebars which I understand to be correct.
Soldering
Happy new year guy's and gals,
After soldering 2 wires together and before applying heat shrink would it be OK to apply a small amount of areldite on the soldered joint to increase the water proofing ?
1959 Model 99 chainguard
Hi, I am currently finding the last of the parts that I need to build a 1959 model 99 and not sure what is the correct chainguard, I have Norton singles so the twins are new to me, I have lots of books and data on the singles but very little on th
Front disc query
Hello, I would be grateful for any advice regarding a bike I am thinking of buying. It's a 1973 750 Commando with matching numbers, and looks pretty sound.
