All Forum Posts
Electra temptation!
Hi all, it's been a while since I posted on this forum but my Navigator rebuild has stalled as I try to solve a gearbox layshaft bush / mainshaft bearing alignment problem which doesn't mean disassembling the engine again.....but I digress!   As i
Laydown box rebuild
Have re-assembled my '55 laydown box as Mike hemmings excellent DVD sevral times. I can almost now do it with my eye shut!
All goes well until I fit the outer casing at which pint the gear lever refuses to move.
lay down gearbox
Canada calling. I have just finished assembling a basket case '53 Model 7. In static mode all gears shift up and down nicely, as they should. But in transit the gearbox shifts from 2nd to 4th, missing 3rd.
A non std carb
I have picked up a fully refurbished monoblock (by Bratby) and am thinking of fitting it to my 99 . The issue is that it’s 1 1/8” bore instead of 1 1/16 , It’s going to fit ok and will be filtered with a decent paper car unit .
Norton Atlas exhaust pipes
Further to my last silencer query will someone please recommend exhaust pipes that will actual fit my Atlas as I have heard several stories from members who say that they have bought exhaust pipes from a very well know supplier and they do not fit
Headlight
What is the correct diameter for a headlamp for a jubilee. My headlamp shell measures 6” diameter, but the replacement reflectors on offer seem to be 61/2 or 7 inch. Any advice would be welcome.
Oil return
I have read somewhere that a modification was made to the return fitting in the oil tank during production of the lightweights, a restrictor to encourage oil up to the cylinder?  It carried over to the heavyweights, or the other way around?
Barrels
I have just been looking at the barrels on my 1959 600 dominator as both have hair line cracks they need replacing but looking at the bottom of the bottom of the barrels the liners seem to part of  the casting I’ve looked at replacement one they d
Upright Oil Leak
Need a bit of technical advice on an upright gearbox in an ES2..
I have an oil leak which appears to be coming from the selector shaft behind the cam plate at the bottom of the gearbox.
REV Counter
I am looking for a rev counter , of the type that would have been fitted to a works bike in the early 1960's , Would it have been an ATRC ?, and in a vibration proof mount perhaps RN1104 ?. Any pictures?.
Model 88 Iron Head
I’ve had my 1957 Model 88 for a couple of years. It’s in great condition but has an iron head stamped T2140. I’ve fitted the correct plugs NGKB6HS and it runs well, although perhaps a bit of pinking when opening the throttle hard.
4th gear selection
A friend of mine (honest!) has an early 50's ES2 with a laydown g/box. When selecting 4th gear the procedure is:
Pull in clutch; depress gear lever; hold gear lever down; release clutch and it then snicks into gear.
1928 CS1 Special
Hi guys, I'm new to the forum and will be posting process as I proceed with a cs1 build... I'm in my 30s and now have a few early Nortons with a cs1 project being the latest!
