All Forum Posts
Electronic ignition
I have a Commando 850 mkIII which I am restoring. I want to keep it original as possible but want electronic ignition. I have used boyer on the past but that was a long time ago now.
RH gear change for mk111
Hi I am trying to convert my Mk3 to right hand gear change I have fitted new inner and outer covers but every time i tighten outer case it fouls the kick-start return spring,so the kick-start won't return,i have built and rebuilt it about a dozen
RAC History?
An odd query that hopefully someone might have an answer for.
The slimline ES2 I have left Nortons in a batch headed for the RAC and was registered in March 1962 in the Inverness area. Obviously it got knitted out with the RAC sidecar.
valve timing 16h
Hello,
I am building a 16h engine (1937), the engine arrived in a box. The cams, etc do not have timing marks. Does anybody have details of how you set the timing?
Castrol R?
I'm trying to identify the type of oil in my 750 racer.
It was last changed by my late father approximately 5 years ago. He owned the bike from late '60s and raced it competitively, then in vintage events.
Mystery tank
I have this tank on my Dominator 88, the frame is wideline 1962 with a 1955 500 twin engine. The tank has two holes for fixing ? knee pads I presume but the holes don't match any that are on the market from the usual suppliers.
ES2 engine anomolies
Recently acquired ES2 enigine, think 1960 but in any case the distributor version, has two mods from previous owners.
Having failed to find similar in manuals, photos etc your help is needed.
16H numbers
can anyone shine some light on the numbers on my 16h engine?
The letters AS are stamped with the numbers horizontally stamped beneath 20131.
Norton V4
Just got back from the Motor cycle live show at the NEC and the Norton stand was buzzing with people with Stuart Garner and team answering questions on the new Norton V.4. What a stunning bike and the finish and detail is superb.
Dolls head bushes
Here I am again!! I have searched everywhere that I know to try and locate new bushes for the quadrant & camplate on my dolls head gearbox & drawn a complete blank.
Dynojet
Hi I have spoken to Dynojet UK a the NEC show and today I received an email that they are considering developing something for the 961 range. They may need a bike in the Lancashire area to look at etc.
rocker spindles
hi everybody,am i right in thinking that the flats on the rocker spindles were introduced to get a better oil flow to the pushrods?reason i am asking is i have an old alloy cyl.head for my 55 m7,it is original, in need of repair, and fitted with s
