Dominator 88
Does anyone have any experience of fitting a 26mm Concentric to a single carb Dominator 88 and if so could you advise on what jetting you used please
Would suggest you ask Amal.
My 88SScame with one 26mm Concentric for some baffling reason. It was remarkably gutless in my case. A single 28mm transformed it (and two are better again, but obviously that's not what you want). I think engines prefer an inlet tract that gets a bit narrow as it runs rather than starts narrow and then widens out a bit.
I wonder if one possible reason for my bikes poor performance on one 26mm carb have been that my bike also came without the inlet passageway sleeves. So the inlet galleries were bigger than 26mm (maybe 28 or 29?) so maybe if you do have the sleeves or if the earlier heads had narrower inlets (did they?) perhaps it will be OK.
I think the main jet was 220, with No 3 slide and needle in centre. I doubt if the carb retailer willknow since they were never fittedby the works (but worth a try I suppose).
Last time I looked there isn't a chart on this web site listing carb settings for odd usages - like concentrics on earlier bikes - but there must be a few users about who have found out these things.
David
Thanks David & John
I have askeda carb specialist and got nowhere and Ithought that there might be someone out there who has already carried out this change
I will ask Amal as a last resort
Thanks David & John
Amals advice was as follows
The recommended starting point when you change to a Concentric is to reduce the size of the Monobloc Main Jet by 20% and replicate the other settings apart from the pilot jet which is controlled by a bush on the Concentric.
