looking into my gearbox without any cogs i focused in on the cam plate when i rotate it its buckled about 2mm, ish. would it straighten up or is it a case of just renewing it .
Barry
Previously Barry Carson wr…
I would rotate the camplat…
I would rotate the camplate and check the plunger locates in the notches enough to be secure, It may be only just hanging in there.Does the camplate rub against the inner cover because of the buckle?.If it works and is safe no problem, What bent it? I would take a close look around for other damage ,don't want a failure on the road.
Barry. i don't know anyth…
Barry. i don't know anything operation wise of the box i am just rebuilding it from parts thats when i noticed the cam plate buckled. i will check for any witness marks. if all ok i will reuse if possible.
Robert. when its tightened up fully i can hear it catching very slightly some where not jamming up. i will have to try and locate where. i don't know what bent it in the first place. theres no damage inside the box. i will check the plunger operation.
Barry
I'm always worried about…
I'm always worried about internal faults on gearboxes causing potential lockup. If the runout is enough it could possibly allow 2 gears to be selected at the same time.
If it was mine I would either investigate straightening it or replacing.
Ian. i don't think it wou…
Ian. i don't think it would take much to try and straighten. i just didn't want to make it worse doing so. if theres any doubt i will replace it.
Barry
Hi Barry..I PM'd you but…
Hi Barry..I PM'd you but just in case you don't see it I suggested the Fork selectors could be reversed. (Pt No:040022) They are the same part and fitted back to back but one quite often has its selector pin (that operates in the cam plate cutouts) ground slightly shorter. If fitted the other way it quite often catches somewhere...can't remember where. Cure is to reverse the relative positions of the selector forks (Swap over)...Worth a check I reckon.
Don't think the slight wobble is any concern.
Les
Hi Les. thanks for the inf…
Hi Les. thanks for the information i have taken a photo of what i have . i havent had the box completely built up as yet just testing the water to see what i need to replace or fix to complete it .
Barry
Attachments image2-jpg3-jpg- Log in to post comments
Barry
Hello Barry to be safe here I would bit the bullet and buy new from RGM Motors Yours Anna J
Hello Barry looking at the…
Hello Barry looking at the photo gives me the impression that they are the same length as if the ruler is not laying straight? It would be easier to use one of those cheapish Digital micrometers you can get for about 35 quid or so, they measure depth as well as width and a "must have" tool nowadays. You can obviously swap them as I suggested as it takes only a few minutes to do. If you could paint some "engineers" blue on the pegs and operate the gear shift, you might end up with a tell tale mark on the tip of one and if you do you only need to grind off a couple of thou. Then again of course, the " catching" might be somewhere else. I was assuming too that this noise is when you operate the shift rather than when the cogs turn as per being driven by the input shaft?...Les
From the photo the pegs lo…
From the photo the pegs look near enough - within .10" or so although it's difficult to see whether the faces are in line - they looks slightly off but this is probably the photo.
WRT digital calipers you can get perfectly serviceable ones for £10 or so from Maplins and the like. I have to say that my M&W micrometers are now gathering dust (although I still use the old vernier caliper for measurements that don't need great accuracy) as I find the digital caliper easily accurate enough for my needs. I've checked them against the micrometers and they are spot on.
Thats interesting Les, doe…
Thats interesting Les, does the selector peg thing also apply to Dommy boxes?,or is it a Commando/AMC thing only?. I had a well worn clutch center with plenty of wear from the plate tangs,but replacing it made absolutely no difference at all.Not what I was expecting.
I seem to remember my camp…
I seem to remember my camplate had a slight buckle and rubbed at some point when it was misstimed,Not a problem though. If the bronze bush in the Kickstart shaft is worn or there is no end float on the kickstart when its all tightened up that won't help.
as i say its a gearbox i h…
as i say its a gearbox i have out of the bike. just running through it to check things over to see what wants doing or renewing
Les . on the first photo the camera exaggerated the look of the gap slightly. the catching i can hear is the quadrant catching the cam plate as per photo. theres no play in the cam plate bush i have placed the selectors in position on the cam plate they don't protrude to cause any trouble. i have a digital micrometer but the battery is flat. think its just a case of renewing the plate.
Barry
Attachments baz-jpg- Log in to post comments
Barry
On my laydown box I had the same problem. I removed the quadrant and found that it had moved on its splined shaft. I tapped it of and refitted with a smear of loctite, checked for squareness of fit and refitted. No more problem. Worth a try?
Hi Robert.. It will be the…
Hi Robert.. It will be the same for a Dommie box or Commando IF it's going to cause a problem but as said, I just can't remember where the pegs hit. I do have another AMC box to strip down soon which will remind me but it will be at least a week away.... It seems though that Barry's problem is caused by the quadrant slightly grazing the cam plate, probably caused by an unfortunate clash of wobbles. I imagine I would attempt to slightly flex the spindle of each part away from each other by tapping it as Charles said he did. You only want the sum change to be about 1mm, even a fraction of grinding will help and not weaken anything....Note don't lever or attempt any bending with the parts in situ. I would grip the protected spindle of each part in a vice and tap gently the area of contact to achieve the slight change to give the 1mm clearance...Les
If you have access to a la…
If you have access to a lathe it would be easy to grip the shaft in a 3 jaw chuck and get a correct idea where the runout is - and possibly even tap it back into line whilst it is there.
Les,charles,Ian,Anna,Rober…
Les,charles,Ian,Anna,Robert. thanks for the help i have decided to renew the cam plate and the quadrant at some stage to sort it out.
ignor the photos
thanks again
Barry
Attachments CAM%20PLATE%20.jpg quadrant-jpg- Log in to post comments
The cam plate seems to be…
The cam plate seems to be proud of the splines at one side (further from the camera) and not the other, which would obviously give the wobble you're experiencing (although a bit hard to tell from the photo).
The quadrant also appears to be quite a way off from right angles to the spindle.
I'm not sure if the plate and quadrant are pressed on to their spindles but given what we see there I would probably try Les's advice in the first instance.
The only concern I would have is that if it's relatively easy to move the cam plate on the spindle then what's stopping it from moving in service?
Ian. thats my worry why sh…
Ian. thats my worry why should the camplate only be pressed on fit with the loads it has to put up with and what could happen if it failed doesn't bare thinking about. you think it would at least have a tack weld just to hold it in position. as i explained in the post above i will renew both of them
just an update on the camplate i am going to renew .so i thought i would see what held it in place. held it in my hand placed a socket in the Centre and hit it the Centre came out. unless someone else has been messing before that doesn't seem to good
thanks
Barry
Attachments camplate.jpg- Log in to post comments
I suppose in theory the se…
I suppose in theory the selector forks would hold the plate in place but like you I would not feel comfortable with what you have.
I would expect that if you used Bearing Fit on the splines it would keep everything together.....
i know you can get a new c…
i know you can get a new center but i think its best to renew the whole thing then again a new one will be fitted the same way. i will shelve it for now and have a think about it.
Barry
Hello Barry your doingthe right thing by renewing the whole things then you can see how much its out, with a set of feeler gauges in between the clearances, anyway do have fun like me with my Manxman Now have nice big fat sparks but in the wrong places so I have to retime the Mag yours anna ji know you can get a new center but i think its best to renew the whole thing then again a new one will be fitted the same way. i will shelve it for now and have a think about it.
Barry
Hello Anna . yes i think t…
Hello Anna . yes i think thats the way to go renew the whole thing. hope you get your mag timing sorted ok.
Barry
If you are not experiencing any gear selecting issues I would be inclined to leave it alone. The selector dogs should slide around the tracks quite easily so look to see if there are any witness marks which would indicate misalignment. The selector cam plate has a long spigot which passes through the wall of the gearbox and is held in place by a bolt coming in from the outside. It possible that the spigot could be out of true but as I said if it's working ok leave well alone.
Barry
