On 1959 Model 50 which adhesive is recommended for fixing new rubber knee pads to chrome tank side panels ?
Mike Haworth
Nowadays I would try clear…
You must roughen up the in…
You must roughen up the inside face of the knee pads which ever type of adhesive you use. I used Evostick satisfactorily.
I use double sided golf ta…
I use double sided golf tape on my slimlines. Model 50's still well stuck since 2000. No luck at all with others, using silicone and even super glue.
Nowadays I would try clear silicone glue. Comes in tubes from craft shops. It keeps things in place but can be peeled off if need be. Unlike Evostick which is filthy stuff.
