Parts Manuals Wanted
Has anyone got any Dominator/twin parts manuals? Please?
Do not answer on here, Private or even personal message please.
Al Osborn.
Al Osborn.
Hello All
Stumbled upon this ebay shop with many NOS Norton parts:
https://www.ebay.co.uk/str/rogerandjulia?_trksid=p2047675.l2563
Could anyone help me. I am looking for crankshaft bearings for a 1939 Norton 16h. The ones that I have removed are all three the same. LR8. But I’ve Had a look on the net and I’ve come up with two roller bearings and one ball bearing.
Hello,
What year this engine N° M37940 F11 ? Thnaks
Hi There.
Can anybody shed some light on where my bike was despatched to.
The Norton Despatch Records show my bike was sent to Corbetts and the colour was blue in a fastback. Its a 1971 750 Commando.
Hi I have been looking on the site for info on getting a dating letter and age related plate far a 74 859 repatriated from the US
my frame has had the petrol tank mounts removed, I can remake and fit but do not have any dimensions to go on.
A member was looking for information on fabricating some mounts and I offered to photograph some. I have been out of action for a month so have lost the thread. If the member can post a mobile no I will get the boss to send the info.
``Reading through some past threads/posts, my attention was drawn to one from early Dec' 2019 seeking advice on the relocation of the writers oil tank, and whether the existing three start oil pump would cope with the new elevated position.
There is a Jubilee tank badge (left side) for sale on eBay at the moment.
Look under Norton Jubilee Motorcycle Parts.
Somebody knows this and has experience with it?
https://www.ebay.co.uk/itm/TRIUMPH-NORTON-FUEL-PETROL-GAS-TANK-TAP-VALVE-PETCOCK-82-1717-NM23305-06-7836/254516049198?hash=item3b4256b52e:g:bVAAAOSwsvVeSzuU
Fritz
Hello, everything is in the title. Who knows the top fork stanchion's inside size and thread?
Removing valve springs from the inter looks easy with this tool, but where do you get one from. I have never seen one for sale. Without one the job can be a bit messy!
Does anybody know the socket size to fit the big brass drain plug at the bottom of the crankcase on a 1966 650SS engine?
Hi there.
I have just joined the NOC after the purchase of my 1971 750 Commando Fastback.
I have a question regarding how to fix a slightly out of shape rear frame loop.
i went to the Telford Classic off road bike show today which isn’t known for its road bike spares, and found a small stash of NOS lightweight spares ..... a set of cams (not bought) but I did buy a set of fork bushes - never seen them before, and
My 16H oil bath case nut has had to be turned down to hall thickness so it goes onto the serrated footpeg far enough for the serrations to pick up the footpeg. Somewhere a dimension is missing but I can't work out where.
As you can see from the picture, my 46 year old switchgear on the RH side is rather cruddy although all of the services still work. Ideally , I’d like to give it a thorough clean and regrease.
Hello
I'm new to Norton singles and have a 1946 bought with the gearbox in pieces. I have a few questions:
Replacing the bushes and spindle. Does anyone happen to know what size bolt will fit into the threaded spindle centre?
Hi, would someone please help as I am going around in circles.
I have a Norton Commando I am currently trying to get registered with an age related plate.
Extract as follows from January 2020 Director's Meeting - Minutes.
10. Confirmation of next meetings. Board of Directors Tuesday 111th February 2020, 7:30pm Combined Officers and Directors 14th March 2020 11am,
While I’m doing a bit of a refresh on my old 74 Mk2a I’ve noticed a couple of things that suggest it’s not quite the unmolested barn find I’d expected.
Should the spring in the beveled gearbox plunger that screws into the bottom of the motor/gearbox be strong enough to allow you to properly fit it into the slots in the selector shaft before you begin to screw the threaded part into the case durin
Hi I have an NVT speedo on my 71 Commando and it should match the Green Globe Tacho, my question, can I change the face or will I have to replace speedo.
Good morning,
Could anyone please help with a brake arm and spring to suit a 1930 Norton 500?
I am looking for a new battery for my Electra and wondering which way to go. Originally they had 2 6v batteries fitted but technology has move on since then so they are more options.
Hello,
Cant' find that anywhere and AN is afraid I'll begin doing some business against them if they gave it to me.
I measured 8°36'.
Could somebody confirm that please.
