NOC Shop - Refunds
Hi. I recently purchased a sidestand for my Dominator 99 from the NOC Shop. The stand doesn’t fit my bike so I want to return it. I went onto the NOC Shop web page and looked on the relevant area for making a return.
Probably teaching my granny to suck eggs...again
69 Commando with early switch gear.
Left Hand switch has 2 buttons to earth plus the Headlight Main Beam/Dip Beam switch
Used black button for horn
Hi all, I have bought a Triton. I naively called my current insurer expecting it to be easy to add it to my existing multi-bike policy. They said they need details of every single modification made.
Could someone please confirm what I think is wrong or shed some light on other theories.
I've seen a couple of other forum post on a problem similar but am not familiar with the mechanical jargon that was said.
A further naive enquiry, I suppose. How do I fix the gear position pointer on the end of the gear lever using the bolt on the end of the shaft within the spline ?
Hello I think these are naive questions but i know little about Nortons (re-joined the club tonight). In connection with re-commissioning a 1946 Model 18 I bought a few years ago. It has sat with an empty oil tank, engine understood to have bee
Hi. Following a disastrous engine blow-up caused by a botched job from a local engineering company I found myself with an oil tank full of iron filings and a glutinous oily aluminium sludge.
Are there any differences in SOHC bevel gears through the years?
I need an upper vertical bevel #A11/767 for my 51 Inter and I am bidding on the one on ebay
I took my Atlas out for its first run yesterday after a 2 year rebuild. Much to my relief everything was fine although I have a query with the clutch.
The NOC-shop are selling the EMGO 17-05589 for the NM20184 rear shock absorbers (for widleline Dommie 88 amongst others). Nice shock absorbers at a good price.
https://youtube.com/shorts/o0r0jo1ckEo
Is this amount of crankshaft end float excessive for a pre war Norton 16h? and what is the likely cause please?
A new puzzle just released from Ravensburger puzzles
Norton Jubilee 3D Engine puzzle with many moving parts ,
maybe even running when properly put together.
A cheeky request.
If anyone has a rear wheel off any time soon, would it be possible to send me/post photos from multiple angles please.
My 1952 ES2 fitted with a Monobloc 1.1/16" is an excellent first-kick starter from cold (air lever closed, half retard, light tickle depending on the weather then the classic technique witha barely cracked throttle.
Hello,
just wondering how to renew my membership, payment wise . i have filled out the details required. but all i can see for payment option, is Paypal. is this correct.
thanks
Barry
Dear All
Help needed in finding +40 Hepolite piston . Thanks
I see a clutch centre washer 22196 listed in the early Lightweight parts list, but can't find any reference about it. Anyone know what it is for?
Cheers, Stan
Any ideas where I can get one of these from,I stupidly didn't tighten it up enough the other day and lost it?
Tia
Bob
Has anyone used an electric roller starter to save kick starting the bike? Which have you used?
Thanks Roger
I have tried using the NOC messaging system. There must be something I have missed, because when someone replies to me using it, the link sent to my email just takes me to the person's name, but I simply can not receive their message.
Greeting from Maine,USA have an 64 Atlas with a problem clutch it wont release the clutch plates enough,Have removed clutch assembly and cleaned all friction plates and checked all plates for damage,wear and made sure all are good condition and a
How does one check that the fuel level is aligned with the dot on the float bowl cover?
Hi Folks , I recently purchased the above items from NOC .
Hi all
I'm restoring a 1962 Model 88 Dominator in Green and Dove Grey.
Did these have vinyl transfers on them. I can't find any pictures. If They do, and you have pictures, please share them.
Check out Mike Browne's results at Manx GP. Over 110 mph lap on an ES2.
I have had to repair the two bottom oil tank holding inserts (threaded inserts) and before I paint the tank again following the welding, I think I should add a better breather system. It only has the small pipe out of the back of the tank.
Hi
Not sure if i have picked the right section, but anyhow does anybody have any news on the new 961? i have put my name down for the new model months ago but no news as such.
Cheers Steve
