All Forum Posts
Leaking kickstart shaft
Hi. When I rebuilt the gearbox on my 1960 Dommie 99 I replaced the kickstart shaft, the bush and fitted an X-ring oil seal. I thought that would definitely prevent any oil leaks from the kickstart but the oil is leaking out badly.
Alloy head modification
Hello, I have an es2 with a smoking issue. I removed the alloy head and found that there was three head gaskets and fibre seals where the oil ports are . The piston is a wellworthy dome top and I suspect its a high compression.
Trailer Insurance
Good morning troops,
My car insurance will only cover my  trailer 3rd party.
I was wondering if anyone could recommend any firms that insure motorcycle trailers?
Thanks in anticipation,
Kind regards,
Sump Plug Torque
Does anyone know the recommended torque setting for the magnetic sump drain plug on a 750 Norton Commando? I have a separate cartridge style oil filter so the sump plug screws directly into the crankcase.
Headlamp internals
Hi all
Does anyone have a photo of how the inside Of the headlamp shell should be setup. Most curious part that im unsure of is the 3 holes down the bottom. Are they all sealed with rubber bungs for cables ? Photo would be great.
