Locating gear position pointer on 1951 ES2
A further naive enquiry, I suppose. How do I fix the gear position pointer on the end of the gear lever using the bolt on the end of the shaft within the spline ? Tightening the securing bolt to locate the pointer binds the lever and impedes its full and free movement. The gearbox is the usual laydown version on my 1951 ES2.
...underneath the pointer that will allow it to stand off the inner shaft without fouling the outer will do the trick.
