We are rebuilding my ES2 engine, and a local well-respected engine guy, whilst checking the bore and piston advised that we should put a couple of o-rings on the valve stems when we reassemble.
Has anyone done this, or even fitted proper valve stem oil seals from a more modern bike? What are your experiences and opinions?
Cheers!
Hi Grant, Probably not a g…
Here is something to try.…
Here is something to try. I do a lot of work on early Ferrari heads with hairpin springs where there is no room to fit a seal. With the guides installed in the head it is possible with some pretty simple tooling to machine a sharp edge on the top of the guide which will act as a sort of scraper to keep the oil from running down the guide. Works better than nothing and won't cause any unintended consequences.
Ferrari tuning tips for an…
Ferrari tuning tips for an ES2! My day is made. Gordon.
My ES2, with a loose inlet…
My ES2, with a loose inlet guide, used 1l of oil on a recent 1600km trip which i was pretty happy with. Mostly 60MPH on the flat and as fast as it would go on the hills (50-55 mph) so working hard most of the way. It smokes a bit on overrun but by the look of the back wheel I suspect more oil came out of the breather and other misc exits than was burnt. So my thinking is don't worry about valve seals.
Hi Grant,
Probably not a good idea, in my opinion, the guides probably rely on that bit of oil mist for lubrication, these engines do use a bit of oil but not excessively so. I wouldn't bother.
Cheers,
Niall
