Hi All,
I have a 1932 model 30 frame and have found out that at the bottom of the downtube from the seat there should be a lug on the frame that a bolt is used for mounting foward footpegs. Mine has been cut of but the remains of the lug is still on the tube.
I will be using the rear footrest lugs but would like to know if anybody has this type of frame which I think was only used for 1932 1933 and are able to take a photo I would appreciate that very much as I want to return the bike as close as possible to origional spec.
Andy
Hi Andy, If you put the nu…
Previously richard_cornish…
Previously richard_cornish wrote:
Hi Andy,
If you put the number 261953669259 into ebay search it should bring up a frame like yours and if you click on original listing it should give you a fairly clear picture which you might be able to save to your own pc and use for future reference.
ATB, Richard.
Hi Richard,
Many thanks for that information, I have saved the picture and now will be able to replicate that part. May not be 100% accurate but close enough will be ok, I will not be using that lug as I want to use the rearset position but just wanted to get the bike more original.
This bike was raced in the 1930s so I guess any extra weight was removed.
Thanks again
Andy
Hi Andy,
ATB, Richard.
