Industrial Archeology
In the course of preparing bits for painting, I discovered the pictured stamp on both of my front engine plates ('48 Inter). Anyone care to enlighten us all on the sub providing this part?
these rolling photos that are not rolling much more like they flick from one to another but stay the same for months time for a change guys yours anna j
Trying to remove the Lucas M1OL mag from my 1956 mod 50 for refurbishment. Am following instructions from Haycraft's book of Norton singles. The set up doesnât look the same on my bike (see photo).
After the short break.
Does anyone supply a belt drive with clutch for Mk3 retaining starter?
Hello,
Going to strip my first Manx/Inter SOHC engine:
- Anything special I should take care of?
- Is there anything easier to do while engine in frame? Like taking valves springs off,
Is there a paper gasket between the mag. and the crankcase on the Dominator can't find any ref. to it in the manuals. Thanks, Campbell
Hello ,
Could some knowledgeable person point me in the right direction ie supplier of
the kinked stay suitable for a 73 roadster disc brake I ordered the wrong one
pt no 06-2323
thanks. oops all ok now sorted
"The Motorcycle Show" on ITV4 are featuring Nortons in a program on December 12th. One of a trilogy.
Tuesday 11 December, 9 pm: TriumphWednesday 12 December, 9 pm NortonThursday 13 December, 9 pm Ducati
Hi, does anyone know of a good tank painter, painting Norton etc onto a chrome tank.
Thanks.
This is all new kit, plus I am no electrician, so I have ordered a loom from Al Os (one you make up yourself), I have a dual output single coil, new alternator standard, will pick up a Tri Spark ignition, will pick up a reg/rectifier, 2 MC capacit
Hello. Can anyone recommend an easy to follow step by step guid on how to rebuild my Norton Commando wheel rim. My intention is to have my front rim rechromed and built back up.
The wheels have been previously dismantled and are now ready for re-assembly, what would be the
off-set of the hubs ?
kind regards
George Roland.
What a lovely surprise when something heavy clunked out of the Roadholder polylope this evening.
So, after 5 years of collecting all (as I thought) the major & minor components to build my boxes of bits Iâve started the rebuild.
greetings all,
just joined up as im the proud owner of my first norton Dommie 99, up to now Iâve been on slightly more modern machinery.... will be very much asking for help/adviceð?
cheers
ross
Trying to get the last of the base gasket off the aluminum cases of my 1971 750. I've done this before but never found a satisfactory way of removing them. I watched a Permatex video online, bought their products and followed their directions.
Hello,
Trying to pull the oil pump out, and heard that two 9/32 x 26 tpi screws would do it.
But is it BNC, BSF, BST, BSP, CEI, UNF ...?
Thanks for your help.
Hello , can anybody help what type of side panels were used on roadster 850 year 1973?
Or from what year or tipe were used steel vs. fiberglass?
Thank you.
Tomas Tesar
This is the first of two National rallies in 2019. This one is Under Canvas, details:-
Last year I was Given (freebe!) a handfull of sample bottles of ACF50. I use this on a rag to wipe over rims and silencer after wet rides . Not only has it stopped new rust appearing but appears to attack existing rust pits.
Just a few words of warning to forum members, I have recently had to return (at the sellers expence 4 orders which turned out to be "Not as described or defective" .I look very carefully at parts but am still decieved regularly.
Can anyone advise as to which is the correct 3 position light switch for a 57 dominator 99 (magneto ign) and should the headlight have the "D" type hole or the larger round hole for fitting the correct switch.
Steve
Do you know what is the clearance (play) piston - cylinder that it is necessary to put for piston JP made in Australia on one commando ? Thank you
Looking through this months Old Bike Mart, I spotted an advert for Craven which has a pic of a late Navigator/jubilee complete with rack, period top box, front and rear crash bars and bar end mirrors, my âexcitementâ was short lived, their website
Hello,
Recently saw an unknown engine number, even in the records. Engine is a Manx or Inter and have this number G10T 45XXX.
Does somebody knows what the T stands for?
Christian
I missed out narrowly on buying a Jubilee Deluxe on ebay yesterday. It went for £252. The bike was local to me so it would have been a bargain.
Checking thro likely issues Its possible that a weak pressure release valve spring may be giving the timing side a hard time.
I saw in an earlier post that when using a new solid state rectifier in place of the big square one on anElectra that one connection goes to ground, the opposite corner connection receives current, and the other two corners are for AC.
I try and get to the yearly AGM whenever I can but think that the 2019 location is going to be a few miles too far for me this time.
