All Forum Posts
Rotor marks.
I just wondered how common it is for the timing marks on the alternator rotor to be wrong.
After snapping several of my ankles I decided to go right back to basics and check the timing marks.
Garner sentenced
Just read on the BBC website that Stuart Garner was today (1.4.22) sentenced at Derby Crown Court over his pension frauds.
He received an 8-month custodial sentence, but this is suspended for 2 years.
Ballast Resistor
I have a Mk 1 Commando 850 and have noticed a white/light purple wire, which when traced, is attached to the ballast resistor the other end could possibly go to the ignition switch, (it's dangling in that kind of position) , I've owned the bike fo
Donnington merchandise?
Assuming that when TVS took occupancy of Donnington, among everything else there would have been some unsold official Norton merchandise: also assuming the new owners would not want any association with the previous owners and so
What am I doing wrong?
The engine is rebuilt, The reason is long and complex and starts with bits of piston ring in the sump,  found when investigating why so much oil was coming out the breather. The ring was obviously broken on assembly as the bores were fine.
Stator Questions
Evening all
Can anybody  help me please
Ongoing issues with Norton Dominator 88 1960
Had bike for a while now, i have fitted Bob Newby belt drive due to primary leak and worn clutch
SU carb
Hi , is anyone running a SU carb, if so can they tell me how many turns out from full in they have. I have 4 turns out after following the instructions but not convinced its correct.
Sprocket extraction
In order to fit my side stand to my Norton 650SS I needed to remove the primary chain case complete with inner part of the case. Therefore sadly I am having to remove the clutch and the alternator.
Mudguard protection
Picked up a chrome Slimline front mudguard today at an autojumble. It's clearly a repro item (you can see underneath it has been made from 3 seperate strips, rather than a single pressing as per original).
Front Fork Travel
HI, I have a small problem with my Commando forks in that they seem to have too much travel when on the centre stand, main problem is that they pull on the lower flexible brake pipe and I believe this could actually stretch so much it would eventu
