Has anyone got the slimline seat base dimensions and some photos please, thanks David
Hi David ,I have some photos…
As far as I know, there was…
As far as I know, there was some differences depending on year. The early with two prongs and terry clips. Disengage when landing after a hump bridge. Later same prongs and a dzus fastener at the rear, bolted to the mudguard. If the later model, I can take some measures and photos.
I think the pan is the same…
I think the pan is the same for both type of fixing ,certainly the foam shape is distinctive and is often lost in the making of repros. I can't confirm that the clipped seat will be ejected after a Hump bridge incident , I can confirm that the Dzus fixed seat may stay on after such an occurance even after the bike has pretty well disintegrated and a write off.after cartwheeling at 70mph. Been there done that.
slimline seat dimensions 1962 model 50 2 prongs at the front
Hi Robert, I'm in Australia so emailing anything would be better
charlton1996@hotmail.com many thanks David
Thanks Mikael, the seat has 2 prongs at the front and engages at the rear with 2 spikes that sit in a lug on the frame, best to email please as I'm in Australia
Dominator Seat
David,
I have a seat you can borrow. I'm in outer eastern Melbourne if that helps you.
regards Ian
Hi Ian, that would be fantastic. Is your seat still assembled or is the cover, foam and pan separate
Hi David ,I have some photos of my orriginal slimline DL seat , Terry clip type fixing on a mobile phone ,PM me you mob number and I will find a 12 year old who knows how to.
