All Forum Posts
R&R conrods
Hi, does anyone has experience with the R&R conrods which can be found on the Feked Classic Bike Parts? Are they reliable? Does one have to rebalance the crankshaft?
1948 Model 18 Clutch Adjust
This should be straightforward but neither of the 'Maintenance and Instruction' manuals I have say anything about clutch adjustment.  I am familiar with Burman, AMC, Triumph and Commando clutches but I am not sure what I am dealing with here.
Oil Tank breather
I have a 1971 Roadster fitted with twin Amals which have bell mouths instead of the standard air filter and have a balance pipe connecting the two inlet manifolds.
Atlas Washer
I hope this does not turn out to be a leftover part but I am trying to find out where a washer goes. This washer fell off when the timing cover was removed on my 65 Atlas.
Norton Gearbox?
Good Evening,
I was hoping you all may be able to help, i bid at a recent auction for collection of early gearbox's i was told that one of them was an early Norton box?. I have attached some pictures so any help would be very helpful.
Wet sump cutout
I know.. I should try to refurbish the pump (again) but yesterday's task was to swap the 'push to make' switch used to turn on the power when the tap is open for a "push to break" switch to earth the magneto when tap is closed.
