All Forum Posts
LED
Sorry another LED question has anyone purchased a cheap bulb from China?
An AMC Clutch Question
I have what I believe is referred to as an "early" type AMC clutch where the chainwheel/basket has friction inserts and the hub back plate is plain. I also have 3 friction plates with external tangs and 4 plain plates with internal tangs.
FullAuto Cyclinder Head
I am trying to learn what is the differences between the Combat head, valve angle, etc verses this newer FullAuto head.  Can't seem to get any particular specs. Anyone out there who has experience and ideally specifications on this topic?
Mk2A Binding Rear Brake?
I’ve been recommissioning a 1974 850 Mk2a Interstate.  The bike hadn’t been used for a number of years so I’ve given it a thorough service and a good going over.  With a break in the weather last we I took her out on the road for the first time.
blanking off 1 exhaust
I'm curious if anyone has blanked off one side of the exhaust on a 2 port head?
I've heard this was a racers trick but  did it actually work or is it just another myth that has followed us over time.?
Clutch Plates
I have just rebuilt a 1973 850 Commando and owing to the fact I have a problem with my right knee I am about to fit an Alton Electric start kit.
Engine Plate Question
Amongst the bits that I acquired with the 650SS project were a pair of rear engine plates. They don't however, fit the 650 crankcase so I'm assuming that they aren't the correct ones. Can anyone identify these plates, please.
Gearbox questions
I hope this doesn't tread on any toes, but I have a couple of questions about the Norton gearbox fitted to my Dad's special.  I don't know much about gearboxes, but i'm relatively handy with a spanner, and I'm trying to get this bike running for s
Alignment
A long, long time ago I did the wheel alignment on my 2A Commando. At the time I must have been reasonably satisfied with the result because I have never been inspired to check it again.
Navigator Oil Pump
With work on the Naviagtor going apace I have come to another typical querky Lightweight Norton question - when I stripped the engine the oil pump had no gasket between it and the crankcase and the two retaining bolts had no washers.  None of my g
