All Forum Posts
Paint code
Does the silver/grey paint used on the 650SS petrol tank have a paint code or RAL number? I will be getting mine repainted soon and would like the colour to be as original as possible.
Oil pressure tell tales
I haven't found a good drawing of the tell tale.  It's one of those "reassembly is the reverse of dismantling".  But I have two, and they are different.  The 16H one is easy to remove, but I don't intend to disturb because it doesn't leak.  Althou
Clutch cable routing
I'm putting together the bits of my 'project' 650SS, more or less in the condition that I received them. Firstly to find out what's missing and secondly, to make any 'tweaks' or adjustments before the bits are painted/chromed/powder coated.
Triton documents dvla
Hello, i'm from spain, forgive my english, I'm trying to make myself a triton, does anyone have the documents of a triton that no longer exists that could be sold ? Or frame featherbed with documents of a triton.
Rotor, 71 Fastback
Looking to fit the rotor to the bike now but on reading through Frick's Tech Digest I read that the rotors 'have a tendancy to self destruct'. Whilst the obvious option is to replace the one I have is it something that is a problem?
Smokey Navigator
Hi there!  I'm a new member and would appreciate some advice on an issue with my recently acquired '61 Navigator.  I've noticed that the left exhaust is smoking a bit and leaving a dark residue, compared to the much clearer output from the right s
Mark3 decals
Does any one know if all mark 3 comandos had    850 comando electric start  writen on panelor did they also have just 850 eventhough it was electric startwritten on side panel .I've just purchased a mark 3 and it just has 850 comando on side even
Wheel nuts
Looking at part number 21773 in the 1959 Jubilee catalogue. Lock nut (for the front wheel) 7/16 x 26 x 3/16. I think 3/16 is the width of the nut and 26 refers to TPI, is 7/16 refer to the nut size? And would that be W, or UNF or BSF?
850 big end socket
Hi i'm renewing by big end shells while i have the engine stripped down and a 1/2 socket is ti small but the 9/16 socket is to big could anyone tell me what size the socket should be for the nut to remove the big end shells on an 850 commando and
Check/grind valve seats
While I’ve got the head off my 1972 750 I’d like to check the condition of the valve seats and lap them if needed. I’ve got a general purpose valve spring compressor. Is it necessary to remove the rockers and are any special tools needed?
Oil not returning .
Hi I have just had a a crankcase mod on my 1972 combat and have put the bike back together it starts first kick and sounds great but the oil isn’t returning at all I undid the sump plug and 3.5 pints of oil came out of the crankcase .
