All Forum Posts
7" Headlamp for Navigator
I'm looking at the picture of Martin Woltman's excellent Navigator Cafe Racer and it look like he's fitted a 7" headlamp, but retained the original Roadholder brakets.  I'd like to do something similar, is that an easy thing to fit I wonder?  The
Oil pump woes
The "tuned for racing" donor engine that I'm using parts of for my 650SS restoration has not been treated with the TLC that it deserves. I had hoped to use the oil pump but it would appear to have been modified.
Clutch drum end play
I've just been fitting an Alton starter to my 850 Mk1 - all went well but on re-assembly I noticed that I can move the clutch drum in and out about 1-2mm.
I can take up this play by tightening down the clutch push rod screw.
Numbers barrels
hello I would like to know the numbers of the cylinder and the cylinder head year 1936 norton es2, norton mod 18 if someone can help me, thank you
maurice
Which Oil
Hi, I think this must be the most often asked question, which oil to use for my 1962 650SS?
Can I use synthetic or semi synthetic?
If I use synthetic or semi synthetic do I have to clean out the old oil?
Norton scooters?
I’ve read all my Norton books, and scoured the interweb for any information on the scooter that appears in silhouette on the NOC app home page on the Models tab, but drawn a blank.
A big thanks
It was nice to see the NOC with a lovely display stand at the Stafford International motorcycle show at the weekend.
Electrickery
Took the head off my Mk 2A this winter to get exhaust threads fixed etc, now appear to have fallen at the last fence. Seems I messed up fitting the coils .
Atlas Misfiring
My 65 Atlas is misfiring and I would like to ask you guys for help troubleshooting it. This has Boyer Brandsen ignition which was working well before it started misfiring. Any help or tips are welcome.
JP pistons in 88
Hi guys
Anybody have any thoughts on JP pistons in a domi 88. I have weighed some and have found that each piston is 35 grams heavier than original hepolites.  How much is that going to affect the balance?
