All Forum Posts
Chaincase
In the Oct 2010 roadholder mag there is an article by John Powellcalled bodging atin primary chaincase, in it there a is mention of a chap called Les Emery who makesmodified sliding disks wherethe gearbox shaft pokes out.
Damaging the Club ?
I must confess to being a little puzzled by a couple of comments on the 961 sub-forum and have wondered just how the NOC might be damaged by member's comments or criticism relating to the supply of the new model.
To quote :-
1930 frame
I have to change the front tube between the steering head and the engine on my mod. 18 1937
How is it fastening to the steering head?
Swing arm differences ?
Please would someone inform me of any diffences in the swinging arm meausurements between a wide line and a slimline frame, they look about the same to me but I am unsure of width andof fitment to the frame and fitment of the rear wheel,thanks
Ignition timing
Hi all - I seem to recall sometime back that some owners doubted the accuracy of the in-built timing scale fitted in the primary chaincase - I've always setup ignition timing using this but are there doubts ref the scale or markings on the alterna
Crank balance
I have a 19S in need of a rebore. Original British made pistons for this engine are now very scarce, but I would prefer not to use Italian GPM if possible.
Rear brake
The rear brake on my Commando has always been MOT passable but always requires a lot of foot pressure togain adequate braking.
