All Forum Posts
ES2 Crank issues
Stripping a 1946 ES2, I find that the big end bearing is completely shot (as is the little end, bore etc). Luckily (thought I) I have a crankshaft still wrapped in greaseproof paper from when Norton rebuilt it back in the 60s/70s.
Valve seal replacement
I have been looking for methods of changing the seals on Commando inlet valves without the removal of the cylinder head. Doing a search on this site refers to the 'rope trick' and also directs to Access Norton site.
Access to on line Roadholders.
Am I alone in being denied access to some of the recently added Roadholders. February, March and April 2011 tell me I do not have enough privileges to access them. I thought we were a democratic club in which all members had equal rights!!!
Dommi smoking
Can someone please advise which way the rocker spindle flats should face on a widedeline 88 and if the wrong way round would that cause major excessive smoke?
Regards. Roger
ES2 Engine problems
I'm looking for some inspiration/guidance!
I have two problems with my engine 55 ES2, one is oil getting into the combustion chamber and the other is a noise a bit reminiscent of a high mileage Ford pinto engine!
Boots
Not sure of this is technical enough for 'General' but we all wear boots. These might be of interest. A good quality £250 motorcycle boot with Norton logo for those who like such things (and why not?)remaindered at £75.
Font query
Does anyone know the font used in the word "Norton" on the official motif? Cheers - George
Electra ignition coils
I'm fitting new 12v ignition coils to my Electra. The new coils have terminals + & - instead of SW & CB. As it's positive earth am I right in thinking that the + terminal will connect to the contact breakers? Any advice welcome.
Clutch lever
Hi, I'm looking for a clutch lever for mk3 commando with the magic 7/8th. between pivot and nipple centers, any help welcome.
ATB John.
Navigator Pistons +20
Hello,
took my barrel away to be checked for rebore, I hoped a +10 would have done as there is a pair in the shop, however it looks like a +20 is needed. Does anyone know where I can get these, or have a pair for sale.
Andrew
Crankshaft Balancing
Hello
I'm sure this question has been raised numerous times, what is the ideal crankshaft balance factor for my 1972 750 Combat motor? I have seen reference to 85%, but I'm not sure that's correct.
