All Forum Posts
DVLA nonsense.
I recently did an engine swap on one of my bikes, having changed the colour as well a few years ago I thought I would get the V5C  updated.
The DVLA now require supporting evidence for an engine number change, a choice of :-
Pre-war owners ?
Do any of you pre-war NOC membership also own Douglas per-war machines.  A colleague of mine has a 1931 600cc 3-speed model T6 and he has stripped the gears on the kickstart quadrant and the ratchet gear with which it engages.  He is desperate to
No Spark
Just fitted 2 new coils to my 850 mk2 and checked with the plugs out and there is no spark.I’m pondering putting the old coils back on and checking again,is there any other things that I could have done to cause this and could check before I swap
Model 50 questions
I recently acquired a 1957 Model 50. I have a question about the clutch and transmission. As purchased the clutch has a solid pressure plate. Looking at the parts book, it shows an adjustable pressure plate with the center screw adjustment.
Leaky chaincase
The primary chaincase on my '36 Model 18 leaks like a sieve so I've managed thus far by spraying chain lube through the inspection hole and hoping for the best.
Crank end float
Just fitting an Alton starter to my 72 Combat only to discover that the crank has 30 thou end float. I have covered about 15000 miles since buying the bike with no problems.
