All Forum Posts
Thank you
Very impressed by the enthusiasm shown by all those that posted comments in reply to my questions about getting my 650SS to start. To try all the suggestions will take some time so I may not be able to reply as to how I got on.
Clutch slipping?
Hi, I have a 36' 16H and recently moved to a hilly area, where it's more demanding for the old bike. I have noticed that on the hills the clutch is slipping at times, (I think)? Just wondering if this is an indication that they need replacing?
Long Stroke ES2
I noticed there is a Model 19 crank in need of overhaul in the NOC Spares.
Has anyone put a M19 crank into an ES2?
Is it more involved than replacing the piston and crankshaft?
Don Anson
Melbourne
starter sprag
Can anyone list the dimension tolerances for the inner and outer races for the 850 mk3 commando. My starter has packed up and is not spinning the crank. I am trying to replace the sprag bearing alone .
Camshaft Endfloat
I am close to assembling the crankcase on my 72 Commando. I have just done a dry assembly with a new standard camshaft with new thrust washer and I have a lot of endfloat- around 70 thou.
Model 30 Engine Case
Happy New Year, all:
I finally began re-assembly on my 1949 Inter Model 30 project. As I was getting the oil pump pushed home, a gear slid out and forced it's way out the other side of the case, ruining 7y of work.
big 4 history search
I have a 1954 Norton big 4 that was purchased new from Eichler of Vienna. On 5/5 1954 by Mr. Karl Dobrovolnik , Andergasse 21/4 in 1190 Vienna. This is the information that I have been given.
Fuels
Please someone advise me as to appropriate additive for ethanol containing petrol to prevent corrosion and gumming in my Hinkley 2014 Triumph Bonneville T100.
pressure relief valve
I recently replaced replaced the PRV on my mk3 850 as a previous owner had tightened it up with a chisel !!!!   I noted that there were no shims behind the spring as shown on the parts diagram. Are there shims only required to take up wear?
2022 calendar
Front cover is William (bill) Harris riding through birmingham bull ring.  Note the wavy roof canopy to right is still there today!
Threads
Is there a page or can someone tell me what thread forms were used for my 1962 Dominator? I want to get rid of the the now rusty and damaged engine and gearbox bolts/screws with stainless items.
Thanks for your help Roger
1952 ES2 Barrel
Hi all. Mike Pemberton has the engine from my project to rebuild but has identified that the barrel is from a later (‘55 onwards) model. I’m therefore desperate to find a replacement.
N15cs camshaft
Just putting a N15 (Atlas) engine together - it was in bits when I got it - just noticed the camshaft timing side has 3 woodruff key slots in it spaced at 120 deg? I thought Norton cams had single key slot.
Piston rings
Does anyone know a company which sells piston rings, though by size rather than for a specific bike?
Confession - this is not for a Norton, though I do have three...
Thanks.
