Re: Old 350 Manx
Just done a deal on a 40M. I don't doubt it's genuine as it has only had a few owners and the last one since the early 70's. Last raced / run in 1980. Never pulled to bits and well known in Norton / old bike circles.
Well,I have been tied up , (metaphorically speaking), getting my stuff back from a guy , who had my stuff for various time periods from September 2015 to last week, but importantly over the past 9 months he had a substantial amount of my property,
Repair kits available again including all new drop in circuit board. Rex Speed Shop UK. Robertsbridge UK. Brilliant way to retain and upgrade what was probably the best of the eighties electronic ignitions.
Hi everyone,
Winter is still keeping the bikes undercover. Have had a couple of sunny warm days in the last couple of weeks to get the bikes out.
Please do any of you know of a repairer who can replace a Veglia Speedometer bezel ? Thanks and regards, Howard
My roadster n/s front fork is very stiff so i'm dismantling to find out what the problem is.
Assembling the upgraded starter motor to the 4 brush system. When I tighten the two through bolts to clamp everything together the armature is tight to turn. I need to give a real handful to get it moving. Is this right.
A rare original side stand for Navigator, etc, just popped up on eBay. Starting bid of £70.
I need to renew the layshaft in my GB8(Dommie 88 / 77) laydown gearbox. Unfortunately I have only a parts list for a G102 (ES2 / Mod 19) box. Could any kind soul let me have the part number for this shaft? On the ES2 parts list it is A2/325.
Does anyone know where I can get some of this?
Is it even 1 paint, or a process to produce the effect?
Thanks Keith
Has anyone used wassell carbs? i need to buy some new carbs, but don't know whether to use Wassell or Amal -
anyone have any ideas?
Does anybody have experience of the Wassell electronic ignition system (by Vape)? Lots of rave reviews of Tri-Spark and Pazon but nothing for this much cheaper one. Any views?
Hi guys - if I fit a sealed main shaft bearing does that mean I can do away with the sealing washer between the gear and the bearing?
Can anyone help, please? I'm trying to find out how many mm BTDC I need to set my engine to get the timing right. I don't want to take the primary chaincase off (again!) as I have just managed to stop it leaking.
Many thanks for the replies. I had looked through the Mk3 wiring diagram for the fuse symbols prior to the post, but of course nothing to be seen.
Does anyone have a Jubilee seat or seat pan for sale? Condition is not important provided the seat pan is sound. The bike is a 1963 model with the later gearbox.
Having used all of the normal means of removing hermatite et al from engines over the years with varying levels of success, I have settled down to a favourite of using the scalpel to remove the old gasket and cellulose thinners to remove the old g
hi
i have recently purchased a 1959 600 wideline dominator
and have been advised the origanal colour was blue
is the blue to be used the same colour given by the club
for the 1960 de luxe
thanks
pete
Could anyone pass onto me the fuse values for the fuse holders packed away inside the Mk3 ES headlight shell. The circuits they protect are: U/Y Blue/Yellow, W (White), N/G (Brown/Green).
Hi I have just built a 1931 es2 and I am about to paint the tanks. Does anyone have information as to what colours ,design/shape of lining is correct as all the photos which I have seen are different.
Can anyone recommend road-legal tyres for track day use, for a 500cc Domiracer with 19" WM1 rim on the front and WM2 rim on the back. Edd Sharratt
Finally got my new purchase home tonight.
I would like to use the original Mag on my 31 model 20.The problem was, back in the late 1980's we had the magnet recharged several times,each time after 4 days it went dead.
Hi all, anybody help with offset measurements for both wheels?
thanks for info on footrest bar, going to get it drilled and threaded
allen
Hi, should the grub screw in the photo be fully screwed in. as i can turn it with a screw driver. it is a tight fit thread wise . is it some sort of blanking plug if so can it be screwed in and tighten up fully.
thanks Barry
Hi all, anybody know where I could get a hexagonal footrest bar plus nots from? cannot find one on any of the usual suppliers (mine has âlostâ one of the threaded ends
allen
My 1952 ES2 is fitted with a 4.00 x 19 rear tyre (Mitas) which is too big in section and in danger of ripping itself to bits on the mudguard bolts. A shame as it's virtually new (fitted by previous owner but clearly not run much if at all).
