Hi, should the grub screw in the photo be fully screwed in. as i can turn it with a screw driver. it is a tight fit thread wise . is it some sort of blanking plug if so can it be screwed in and tighten up fully.
thanks Barry
55 es2 engine,
Attachments barry-grub-screw-jpgHi Barry, mine is screwed…
Hi Paul , thanks for that.…
Hi Paul , thanks for that. i wasn't sure whether or not to just tighten it up . when i first looked at the thread i thought a lock nut had fallen off but if its a case of it just screws in and tightens up thats good enough for me.
Barry
Same bike as mine, Barry,…
Same bike as mine, Barry, Just checked it and mine protrudes about 1/8" with no locknut and not shown on the parts list - or in an earlier issue (1950). Hope this helps.
George
Hi Barry, Every days a sch…
Hi Barry,
Every days a school day! .......didn't think my 1960 M50 had one but it has, just as George describes about 1/8th showing, no lock nut. (not as visible as yours in a slimline frame)
Regards John O
George, John, thanks for t…
George, John, thanks for that .it looked to be protruding more than it did . i only noticed it because i was cleaning and painting the lower frame rails in that area. its screwed in tight now. glad i noticed it..
thanks again, Barry
yes Dan . i have put some…
yes Dan . i have put some on the thread near to the screw driver slot end so it doesn't get into the inner workings.
thanks, Barry
Hi Barry, mine is screwed in tight, from memory, itis a drilling blank off for the oil return from sump to pump. Best make sure it doesn't vibrate out.
