Doherty Levers
Does, anyone know if genuine Doherty levers can be identified by distinguishing marks or stampings?
Many thanks
John H
Many thanks
John H
Hello all fake or repro parts are being sold on eBay these are slimline mudguard sold as wideline mudguards and these mudguards are not completed there is No bridge peace where the stays fit and No wiring tags to hold the wiring for rear tail ligh
My Commando is wired positive earth as normal.
Hi All
Can anybody give advise on setting up MK11 Amal single carb on the above, it's brand new and has thechoke leveron the top of the carb.
Thank You
Kind Regards
Mal
Can anybody please help by clarifying how the small non return valve that sits in the orifice adjacent to the oil pump feed bush is meant to be retained.
I've noticed that a number of brand new unregistered commandos and dommies are starting to appear on the net at a great saving of over £2K on list price, which seems tempting.
fiddling about with photo sizes trying to make them smaller to add on the site. anyway while messing about i copied one of me photos off the site i had put on a bit ago and then pasted it to my desktop.
After finding a couple of my 12v sealed batteries dried out,dead and sulphated I'm thinking that an earlier intervention with some top up water may have saved them. Now looking at my 6v Burlen which has sealed ports under the name strip.
Now the ES2 story approaches it's end. All parts are now purchased and what's left is a bit of paint, assembly and then the MoT.
on my es2 engined 19s framed mongrel i am just placing the parts back on it to see what fits most of which is none standard.
I know it's this year we are celebrating the 50th anniversary of the Commando....but is it not also the 70th anniversary of the Dominator.
The first ones were built and shown November 1948.
Just a thought.
This bike is for sale near the famous castle Neuschwanstein:
Help needed here,
I am trying to find out anything about a 998 "featherbed" Commando.
Bought as an early (1968) 750cc, but the log book says 998cc
Engine number MV51048, which doesn't match any data base that I| can find
I am in the process of re-fitting the cy head on my M50, (a very minor oil leak from the front drain hole ) and wondered if it would be better to fit a copper gasket instead of the alloy one, (for various reasons I don't want to 'lap' the he
Letâs all have a go at posting pics, hereâs mine,took my sons girlfriend out for her first go back of bike, this ended up on â Instagramâanother new social media form few of us are on,but all her young mates know what a 961 is now ,showed u mine s
Hi. I am trying to find 2 allen nuts that fit on a distributor adaptor that adjust the tension on the ignition timing chain on a 1961 dominator 99
Is there a difference between Single, Dominator and Commando oil pumps, besides the drive gear? Could I use a Commando oil pump in an early Dommie 88?
I am thinking phoney baloney , unlesswe could find some factory records and prove it.
Just tried to access the shop but only received the message below?
The server encountered an internal error or misconfiguration and was unable to complete your request.
Is there a difference between a Commando rear hub and any other rear hub from a Heavy twin?
Many thanks
John H
Hi , silly question time perhaps, I have my f/back long range tank back,painted and polished, there are of course no recesses for the circular tank badges so script transfers I assume are used, however can some one perhaps explain exactly where th
Hello lads, any one recommend a good insurance company. My old bike are with specialist bike insurers I enquired today about my 961 but they think they will struggle as they only normally cover old bikes.
Your thoughts please
If the rockers, and spindles are removed, is it possible to extract the pushrods without removing the cylinder head?
Can anyone suggest a competent outfit (preferably in the South of the UK) who can re sleeve my master cylinder to 13mm? I am thinking of buying a kit from RGM but they don't actually carry out the engineering work anymore.
Hi Everyone,
i am thinking of a ground up rebuild of my 1974 2A Commando,I would like to keep it looking pretty much as standard but can anyone suggest any sensible modifications I could include that would improve on its original spec'
Any of u like minded 961 er,s fancy a natter & catch up then come along on SUNDAY 25TH MARCH, location to be decided, that Sunday is the first one after clocks go forward, temps should be more acceptable & gives us a chance to plan, as mos
Hi guys,
Iâve seen a 72/3 750cc roadster with orange tank and side panels, could someone please tell me what colour it is, and is there a modern equivalent?
thanks in anticipation, Tony
