Led bulbs
Hi, has any one fitted led bulbs ?
if so are they any good and is it possible to get 6 volt for a positive Earth Norton ? I have a feeling that they will only be suitable for negative earth.
Hi i wondering if my dads Norton Navigator is still about. He bought it new in 1961 i think. Full fairing model as attached picture shows, with reg number 183 LYC.
A dolls head adjuster bolt made a successful bid for freedom the other day. I have just received a new one (i.e.
Hi all,
On stripping my MK3 gearbox i find the neutral switch rivet head on the cam plate is badly grooved (see pic), can this be easily replaced ?
Any tips gladly received.
Kind regards,
Ian
My Electra came with a speedo marked up to 80 mph. I have been reading that the Electra might do 90 mph. Do I have an incorrect speedo fitted? Just curious as I don't expect to be getting to this speed level.
I've been riding my recently acquired navigator, done about 60 miles now. I'm surprised how noisy the exhaust note is. I think rather too noisy, I wouldn't want to ride any great distance without ear plugs! The silencers look to be of the type/
I am aware that this topic seems redundant. However, I have some news (I guess), and a solution.
I have a 1972 model and I rarely use the side stand as it leans the bike over a lot and to me it looks to far. On investigation I don't have a normal set up, the fixing point on the frame on mine is missing.
Hi, would my 37 civilian model16h have 1" or 7/8" handlebars please and what are the differences between this and the military model?
Thanks,
Gary.
Hi if anyone can help out with this? Had a very frustrating experience having bought new steel side panels one from AN and one off ebay. Beautifully painted but they dont fit!!! Decided to go with original old stock.
My 1956 Dominator 99 has a bad clatter from the engine. Very audible.
It is not a bearing rumble. nor a tappet rattle, nor a chain slap.
It seems to be coming from the front of the engine.
Parts referred in this post are named as they are in the AndoverNorton web site with URL immediately following.
https://andover-norton.co.uk/en/shop-drawing/65/chaincases-chains-sprockets-clutch-alternator
Does anyone know which model this cover is likely to be from?
It is stamped inside with 19256, Birmal, and 53. The 3 holes are for a tacho drive I assume.
cheers, Andy
Wished, I had come across something as rare and unusual as this Manx framed twin!
John
Hi, it’s me again.
The ES2 was really easy to start until I filled a nearly empty Primary Chain Case with 1/2 pint of oil.
could it be linked or is it just a coincidence ?
it was all going so well !
Hi all
Does anyone recognise these rear set components that I have acquired off my buddy, he's not sure what they fit?
Hi, I have a 1954 ES2.
it is now very close to getting back on the Road after more than 35 years. But I am struggling to find the part number or supplier for the large rubber inspection bung on the primary chain case cover.
Please help me from my nightmare of an imported project now found to have a shattered flywheel and bent rod amongst other problems. I just can not get the worm drive nut off the T/S crankshaft which is stopping me splitting the cases (or even rem
Useful Sources:-
Books like these are excellent and have tons more of valid information. More so than the often empty skimpy manuals of today!
Norton Motor cycles; Edgar Franks 1949-1952, My Edition C. A. Pearson Publications;
Regarding pre war speedometers as fitted into the panel in petrol tank on a 1938 Model 18 and 16H :-
Were these chronometric or some other type ?
Were they 2:1 ratio or some other ratio ?
Can any recommend where I can have a full restoration done on my 1947 model 18 fuel tank, including a re-chrome, anti-ethanol lining etc?
Does anybody know what the correct type of magneto is for an international from 1939?
Hi. My basket case Dommie 99 (1960) came with a very tatty oil tank/battery box mounting platform so I’ve been looking for a better one.
Considering how I built the seized, rusty,water filled Basket case 25+ years ago with very little other than a rebore ,valve grind and new shells, its done very well.
Hi, help anyone? Just bought a 1972 commando. It has. Decompression lever on the handlebar. Can anyone explain how to use it?
thanks
Dave
I have carb bodies marked R300 928 and L301 928. In both cases there is no hole for the pilot jet . Please see photos. Is this how they were made ?
