All Forum Posts
Rechroming silencers?
I still have the pair of Dunstall Decibel silencers that I bought way back in the 70's. One's not too bad, but the other has quite a few places where the chrome has been scraped, is peeling around the exit, and generaly in a poor state.
parts refund
Need to return some footrest rubbers. ive emailed spares for a return address but no one has got back to me. Would anyone know the return address.
John.
Future of Norton Spares?
Hi, having read the saga of ace conman Stuart Garner, I wonder what the situation is if he has an input for the manufacture of all Norton spares for all models. I understand that Donnington machines are most affected.
keeping your norton safe
hello Now I see there is a motorcycle crime reduction group giving us some advice on how to keep your norton safe  and some of this advice is not good advice   Now in the last 20 years I been working in security   and for all the locks and devices
Engine bore wear
My 1935 16H was a 1 owner machine with original plates dug out of a barn 51yrs ago and was out of use before that. The wear in the bore is around 16thou (difference between unworn top of bore ...79mm...and just below the unworn lip.
Pictures in text
I've a feeling this has been asked .
But how do some posters manage to place pictures (of different sizes) within message texts?
Norton model 18 1946 Piston
I wonder if anyone knows around what weight a piston should be for my Norton model 18 1946 (Ex Argentina) The bike was in bits with 3 incorrect piston, I made one fit but it vibrated quite badly, since then I have bought a standard compression plu
modern petrol
Will I need to change all the rubber and plastic  that will be in contact with modern petrol e.g tubing within an original 1959 Jubilee to accommodate for the alcohol in the fuel?
Dynamo output
I have recently changed to a 6volt 35/35w halogen headlight bulb, on my early Dominator.  I find the dynamo can barely cope with the current required ( in Spain headlights must be used in daytime, even on historic motorcycles ).  I  have cleaned t
Membership Cards
Quite disappointed when my card {bit of sticky paper) came through, I have joint membership of other clubs which still have individual cards but this joint bit of paper is cheap.
Ammeter voltage
Hello my Dommie has been converted to 12v sometime in its life. Ammeter is bit scruffy and want to replace it, are they voltage sensitive see so many advertised as 6v
thanks
