All Forum Posts
Snake Pass
Just seen on the Guzzi forum that Snake Pass (A57)  will be closed 12 to 25 October to repair a landslip & some other work.
Big end size
I need to know the FACTORY SPEC, for the con rod big end eye dia. for a 1.500" Norton crank journal. Domi 99, Factory spec for the big end journal = 1.500 - 1.505" what is it for the rod?
Weight of Navi Piston
If you have access to a +20 Navi piston (c/w rings & gudgeon pin - but no circlips) and a set of scales - can we have some measurements, please?
I'm chiefly interest in OE Hepolite pistons - to see how much variance there is.
Sidecar width
Hi, when not racing I’d like to take some transport in the garage of the camper, I’m thinking of a sidecar on one of my singles but don’t know if it would fit in the van, I’m guessing it would be tight!
brake pedal
Hi, Just purchased my first Norton. Its a 1958 polychromatic grey 99 which I have been doing a refurb on. My question is that the brake pedal has excessive side play which leaves it resting under the dome nut of the side case cover.
Headlight lens
My front number plate clashed with my headlight over the weekend completely smashing it. I am now in search of an original replacement if possible.
1949 es2 8inch lens, 6volt.
A-Reg rectifiers
My electrical skills (still more electronic ones) don't extend much beyond checking continuity with a battery and light bulb, so I'd be interested in Al Osborn's comments on the following:
Green spots
Good morning. Am refurbishing a 850 commando...doe,s anyone have the tacko and speedo ,the green spots ones. Maybe just one ,or one that need work doing ...
In England cheers
