Front brake squeal
I have a loud squeal from the front brake on my 1955 Dommi. 88, it is worst when applying the brake lightly, if applied hard it stops.
Hi, I am looking for 2 sets of contact breaker and 2 condensers for my 1961 Jubilee. Any contacts (!) that I can try before the club spares scheme is up and running in August?
hi , I am reading the letter concerning oil pumps, I W commented on the Suzuki TL 1000and states that the Suzuki engineers placed the pump before the cartridge filter , hence the damage to it .
I first posted the question in the Heavy Twins section but it's really a general Q - especially as I've just bought a 1961 Navigator de Luxe off eBay!
I've got a 1966 Atlas that was fitted with Boyer electronic ignition when I bought it, but it went wrong, so I refitted the magneto.
If you try to post by quoting a previous message, all of the content gets included in the quote section (red bar and greyed out)
Does anyone who maintains the site monitor this stuff?
I have heard say of a Norton parts supplier in the area of Southport/Ainsdale/Hillside. Does anyone have any experience of such a person and if so, do you have contact details?
Cheers chaps and chapesses.
Calling the owner of a 1961 Norton 500engine 94615/122.
Has anyone experience of fitting a 120 section or even a 130 section rear tyre to a mk3 commando ?
I realise I would need an 18" rim but curious to know what is the widest section tyre it"s possible to fit.
regards,
Some where inside this box of cyber space I spotted a chart that had info on gearbox numbers. I can't find it. Anyone know where it is, or similar info that outlines what the G102, G101 numbers indicate??
Bob
I've just fitted a single Mikuni VM34 to my 750 Commando, jetted IAW the american NOA notes. I could not get it to run properly at tickover.
In case some have interest :
I have an almost new (tread depth) but very old Avon GP 4.10 H 19 tire fitted to a WM2 19 rim.
These were standard equipment on Norton Commando front and rear roadster and combat models ?
Hi all,
I am a new member with no bike at the moment, I am looking high and low for a Commando can I beg advise on buying. 750 or 850 old dog or perfect ? e-bay or small ad's, many thanks Steve Kirby ( Essex )
I am trying to find a handbook or service manual for my 1959 ES2 has anybody know where I can get one.
Regards Alan Crocker
What is the difference between a 99 engine and a 99S engine please.
When I open the site I look at the changes that have happened since last time I looked. These are usually changes in the recent messages column on the right of the home page. looking for chat and interesting things happening with other members.
Our next planned Yorkshire branch ride out is on Sunday 6th June, the destination is Matlock Bath, in my opinion its one of the best ride outs we arrange (unless the rain god intervenes!), so please do your best to get your Norton out an
could one of you learned gentlemen again assist me with the date of my other machine please, frame and engine number is R 1390752, again i have no documents to assist me , thanks very much.
Can anyone tell me the year of my frame and engine please , the frame # is 13..101398 and the engine has 99s 7473 on it and 98123 seperately. did they leave the factory together ? , thanks for your help ...
Ahh! This time it works! Firstly, apologies for the previous abortive attempt to start a thread on this subject - computer problems meant that I could not get past the title...
Hi, I've bought an Amal Mk2 from RGM for my 77' Mk3, it was supplied witha 15pilot jet in the float bowl and a blanking screw in the carb body, is this right? do you leave the blanking screw in position?
Hi Gents and occasional Lass,
I was wondering whether the roadster tank, side panels and seat are a direct swap for those on my interstate ? like popping home to change for the evening !
Hi to one and all. I have a '76 850 ES which has been converted to belt drive and has most of the ES guts removed. I do have the starter motor which is the original 2-Brush type and one of the gears but no sprag clutch etc.
The battery on my 72 commando vented acid from the breather pipe.I didnt notice till too lateresulting in a nightmare of corrosion at the alloy rear wheel, chain guard, brake linkage etc.
I know very little about what constitutes 'concours' standards but assume it must have the bike looking like it did ex-works.
Whilst I am interested in standard Nortons (own a fairly standard 1946 Model 18) I'm sure that I can't be alone in having an interest in Norton specials. (as well as my model 18 I have a heavily modified Commando.
Anyone have an idea where I could find an air filter for my 650 Mercury? It is hot and dusty here in Cape Town and I would prefer to filter out the bits.
thanks
Dominic
Can anyone tell me which concentric carb, jets, needle, slide etc would be required as a replacement for a monobloc 376/67 on a 1960 Dominator '99'. Robert Gittins.
By way of reply to Phil Hannams comments re oil pumps and filters in last months RH.
Hi All, Can anyone tell me what is the correct or recommended6 volt battery to use in a 1961 Model 50 (Slimline frame)?
Many thanks, Alan
