All Forum Posts
Dismantling gearbox
Ive got to the point where the layshaft is to be removed and Ive noticed that the sleeve gear is sliding up and down 1/2 inch through the shell. The only reason its not sliding further is that its teeth are fouling on the teeth of gear 3 Lay.
V6 engine concept
Hello all I have been thinking Of a V six based on the bore and stroke of the Jubilee 60x44 which will make a nice 750V six, with 4 valves per cylinder DOHC Geared valve train with a bolt on gearbox made from aircraft grade alloy bullet machinedca
Older rider problem?
I find with a full-face helmet on at my age I can't turn my head quite far enough to see the cars behind. A good handlebar-end mirror has helped a lot, but I'd be happier in poor light if my "dynamo" Domi 99 had trafficators.
Fork leak
After updating a Roadholder fork with new stanchions, bushings, paper gaskets and oil seals, one fork leg leaks. It is leaking out between the seal holder and the slider. Never had that problem before on any forks I've worked with.
featherbed frame
Hi
Please could any one tell me, where i can get a new Featherbed frame manufactured, Ive been looking for a good secondhand one for a while but they appear to be a little thin on the ground at the moment.
Cheers,
Steve
Calendar prices
I've just ordered 4 desk calendars and the ad in the Roadholder says price is £13 including postage and VAT where applicable.
when I go to complete the deal via the NOC shop the price is £17
New spares
There have been a number of threads on the forum asking what 'new' spares are available from the NOC shop, below is a list created from memory by Ian Somerville, Merchandise Officer of theNOC.
500T Parts
New here so be gentle!
I am in the process of re-commisioning my 1950 500T. Does anybody by any chance have a rear mudguard stay to copy or whether anyone currently reproduces them?
