Master cylinder re-sleeving
Can anyone suggest a competent outfit (preferably in the South of the UK) who can re sleeve my master cylinder to 13mm? I am thinking of buying a kit from RGM but they don't actually carry out the engineering work anymore. They supply comprehensive instructions but my workshop doesn't have the necessary kit to ensure that the bore is drilled accurately to take the new sleeve. The only other option seems to buy a new master cylinder from Andover Norton at about £200...Any suggestions would be appreciated,
Madass on Access Norton forum does an alloy sleeve and seal kit that can be installed at home, the OD matches the master cylinder and is loctite in position and you just need to drill and deburr the fluid holes.
