Dominator 88 pushrods
If the rockers, and spindles are removed, is it possible to extract the pushrods without removing the cylinder head?
I don't think it possible. But I have removed and replaced the head on the roadside and re-used the composite gasket .
You are probably right Robert. However, it is worth a try removing one, to see if it is possible.
hello yes as long as you have elastic pushrodsyours Anna J
Thanks for the sensible replies, here, and by email. Since it is not possible, the head will come off, on the next warm day!
