All Forum Posts
Norton commando clutch
i cant seem to get my clutch to work properly I clean it all out and wash the plates put it all back together and it works perfect after about 50 or more miles it starts to drag and I have tried all grades of oil but the same problem any suggestio
NOC app
Am I the only one who uses this app? I thought it was going to be great but it seems to have just petered out. Using it on an Android pad it no longer updates, photos can't be uploaded (or deleted), events have dissapeared .
Commando primary chain
I have been looking on line for the specs on a Commando primary chain. The ones I see are Renold. I think they are 3/8" pitch triple row with flat side plates, so that it can run on a slipper tensioner. Exactly how wide, and how many links?
K2F Mags.
I have both a ATD mag. and a manual mag. On the contact breaker plate the upright stem that pivots the heel is hollow on the back side. The manual mag. has a spring loaded brush in it. The ATD mag. has nothing in there.
Dommi timing
I'm doing magneto stuff to my 1957 88. i ACTUALLY HAVE A LEAK FREE CHAINCASE AT THE MOMENT! Not wishing to disturb it I stuck a Helix protractor on the crank end (picture herewith) with Blue tack.
Field Coil resistance
I've checked the field coil resistance on my Lucas E3L dynamo by measuring the resistance of the instrument then deducting that from the reading taken across the "F" terminal and earth. The answer is zero. I understand it should be around 3 Ohms.
Dunstall bracket
Has anyone got a Dunstall silencer mounting bracket they would sell, provide dimensions of or send me a template so I can make a pair. Attached picture shows what I'm looking for.
Terry.
indicators
Hello. thinking of fitting some indicators to my bike. will fit the fronts onto the headlamp bolts on the shell. but just wondered what would be the best position on the rear.
