99 Swinging arm shockers.
Can any of you officianados tell me what I am looking at. Amongst the boxes of bits that form the basis of my 1956 Dommie 99, I have come across one pair of suspension units that are the right length but do not fit into the mounting plates and a single unit with a bright shiny blue spring (obviously brand new) that is the right length and does match the lugs. The one that fits has no visible identifying marks and the pair only display a part mark: 64052110AACX. If the one that fits is right I don't know how to find one to match it and if the pair is no good to me, how do I offer them to someone else if I don't know what they are. I am expecting that the outcome of this conundrum will be to bite the bullet and buy a new pair and throw the other three away. Any thoughts?Attachments
image-jpeg
It is not uncommon that you find shocks where rubber and bushing are replaced with a different size bushing. Length and inner diameter can vary. Same shock was sometimes used on different marques and models. If you are lucky a replacement of the bushings will solve the problem.
