Hello,
As a new Norton owner I'm looking for a little advice please.
Hi All , hope you are doing well.
Question to British and Europien members.
Hi everyone hope we are all well :) for those that don't know I'm one of the younger members in the club in my early 30s.
Hello, since dommi heads are alloy can we assume it has hardened valve seat inserts?
Regards Roger
Refitted battery after charging. When turn ignition key on amp meter normal deflects slightly to left but today nothing and no sign of life on kicking. Turned light switch to on position to check lights but no lights.
Hi. I’ve just fitted the engine into my 1960 Dommie 99 project. The centre stand bolts are hollow and the holes through them align with holes in the engine plates.
Hi there - I need a petrol tap for my Classic. I can only find one for the Commander, which looks similar but it is mounted on the offside - if I fit it to the classic the fuel outlet will point forward, not a big deal but would like correct part.
Has anyone got a recommendation for a supplier of a set of shoes ?, They need to have steel facings and linings that stop. I will probably have to send them off for re-lining as that seems the only way to get proper linings ,but it would be
Arthritis now causing some discomfort with my clutch hand when riding mk3,i have fitted the Venhill featherlight cable and it is routed correctly and too be honest probably best i have had but still caused some pain when in traffic ,so big questio
Can any one recommend a good method and product for cleaning out the petrol tank of a 1956 Dommie Thanks in advance for any replies. Campbell
I suppose some of us have thought about leaving our beloved Norton/s to the club in some manner, but are unsure of the most appropriate way to go about it.
Afternoon all ,
I am fitting a tri spark mosfet regulator/rectifier to my 1972 750 commando ,any one got experience of them ?
The wiring instructions look simple .
I've been unsuccessfully attempting to eliminate the probably not quite 2 drips per second petrol leak from my carburettor. The float bowl is positioned level. The factory metal float has no leaks.
Hi. I’m rebuilding a 1960 Dommie 99 engine. At the moment, the course of play seems to be ‘fix one per, then find two more’, so ….
could anyone tell me if the two 3/8th studs at the front of the head are cycle thread or BSF as mine have stripped in the head and i need to order a helicoil kit.
Ive recently replaced the rear brake pads.
I've just acquired a nice Mk3 Roadster. I'm having a problem with the rear disc brake binding after a very short run.
Hello all I hope everyone is doing well, I am in need of some help in regards to engine and transmission mounting plates for a 1960 Dommie 99.
Hello all I hope all of you are doing well. This so happens to be my first post on the forum being a new Norton owner and owners club member. I am on the look out for a NOS, Slightly Used or reproduction Amal Carburettor for an ex WD 16H.
Does anybody who lives near Shropshire have a Commando seat I could borrow whilst I have a new one made? I have to leave mine with the seat maker and I have to ride my bike back whilst he makes the seat.
Hi. I’ve started rebuilding my 1960 Dommie 99 engine. I’m at the stage of fitting the crankshaft into the crankcase halves.
I’ve got the recommended Superblend roller bearing in the drive side and plain ball bearing in the timing side.
Finally managed to obtain a pair of front mudguard stays for my Jubilee Deluxe, now I just have to fit the mudguard and the front brake adjuster bracket !
I have asked this question before but never had a definitive answer. Is there a TLS brake that will fit directly onto a 56 Dommie 99 hub?
I’m looking for an oil supply line ball valve for my Seeley Commando to stop wet sumping - only decent ones I can find all have reduced bore (e.g. 6mm).
Swopped to rear sets for ergonomic reasons to ease the pain of interstate footpeg/tank position with the Z plates Does the cable still have to exit under the rear silencer rubber bobbin now there ,s no rear footrest Straighter run over the t
The splines have worn away on the kickstarter on my 1961 Navigator. I've looked on the spare parts list and am a bit confused. Can I just purchase a replacement? And what is the part number?
Thanks.
Andy James
Is everyone's 12 amp Wassel ammeter as odd as mine? This is the second new one I've had, the first one was completely broken when I took it out of the box and this one looks like its going to fall to pieces as soon as I go over the fist bump.
