All Forum Posts
1953 ES2 dualseat
I'm restoring a 1953 ES2 and have a (BMS) copy of the 1950 Norton parts list, together with the supplements for 1951 - 1954. I can't find any mention of the dualseat introduced in 1953 (or even the 1954 dualseat).
Slipping kickstart
Still no joy curing my kickstart problem. Has anyone experienced the Kickstarter slipping on compression sounds like the ratchet pawl is jumping the internal teeth on the layshaft 1st gear. Any comments welcome.
1937 16H
Should my 1937 16h have a "Big-End Restriction Jet, Spring and Holder please?
are these available through the club?
Can Anyone suggest where I might get an "Oil Pressure Tell Tale Body form please?
Thanks.
Engine Oil
Many moons ago when I was riding my 1968 Mercury I used SAE40 engine oil. Things have moved on so what it the current thinking on engine oils, whether to use single grade or some multi grade modern oil?
Kickstart shaft
I'm trying to fit a new kickstart shaft to my AMC gearbox.
The replacement from RGM is too large a diameter to go through the inner chain case bush. It looks a few mm longer too.
So frustrating!!
Japlack paint.
Just used some  30 year old paint  on some pipework.  Amazing  colour depth and shine, and did not even need stirring  after sitting so long.   Does anyone use it on bikes?.   Certainly sticks well to hands hair and face.
battery polarity M50
I'm in the process of sorting out a 1957 M50.  As I received the bike it was hooked up as a Negative earth.  The wiring diagram for this year shows it as a Positive earth.  The wiring is not original and I do not know the history of who's had thei
cracking exhausts
Hi - the bike's a MkII commando from 1974 and has exhausts connected by a balance pipe. Standard in all other respects except for the large full length ex-police fairing which keeps me nice and warm and dry.
Fork length on mk3
hello can anyone tell me the correct fork length for a mk 3 commando,1975.i have bought some with what I thought was the correct part number but they seem to be short. Thanks
Dominator side stand
I am rebuilding my 650SS and want to install a side stand. The original has long gone. Unfortunately in the NOC shop the part is out of stock so I am looking at the offerings from Norvil Spares, Andover Norton and RGM.
Valve clearance?
I noticed this question of the FB forum.
The gent asked if he should use 0 clearance on his 31 500 OHV Norton as the clearance increases when hot.
My 31 requires .002 In & .004 Exh
1972 Engine Changes
Does anyone know engine number or date when the cover over the rear timing case was replaced with a solid casting. (I am referring to the cover over the early points position).
Steve
